BFG Radials?
Old Aug 31, 2005 | 09:15 AM
Tippyman's Avatar
Default BFG Radials?
I want a pair of BFG Drag Radials that i can put on my car and drive to the track with and then take 'em off when i get home. (i'm looking for those street legal ones, u know.) only problem is, i don't know what size tire and rim will fit on my hatch (96 civic hatchback. b18c1 engine swap if that matters). i have 195/50-15 on my car now, but i wanna get whole diff rims just for the front. anyone got a link to a rim and tire package i can order online? and tips would be greatly appreciated. thanks!
Old Aug 31, 2005 | 11:57 AM
Undercover_Skank's Avatar
tou can still keep 15 inch rims in the front with some 205-50-15 bfg radials
Old Aug 31, 2005 | 05:04 PM
vaporboy12's Avatar
Default Re: (Undercover_Skank)
you can run the 205 or the 225 no problem
Old Aug 31, 2005 | 06:38 PM
Rad Racing's Avatar
Bart Taylor Look-alike
Default Re: (vaporboy12)
I'm running 225/50-15 on a 92 HB with a H22 and they work quite well. There is a noticiable difference between the 225s and 205s.
Old Aug 31, 2005 | 08:06 PM
fmfkid250's Avatar
Default Re: (Rad Racing)
i drove on the 225s for 3 months of abuse daily driven
and i went 11.5 on them!! sick tires
Old Sep 2, 2005 | 07:32 AM
BlackCRX's Avatar
what kinda 60foots were you guys pulling ??
very interested in these tires as well, scared to break another tranny if i go back to slicks
Old Sep 2, 2005 | 07:42 AM
hondaguyef's Avatar
Default Re: (BlackCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX &raquo;</TD></TR><TR><TD CLASS="quote">what kinda 60foots were you guys pulling ??
very interested in these tires as well, scared to break another tranny if i go back to slicks</TD></TR></TABLE>
60 footers on these can range from 1.7's to 2.1's and higher. It all depends on vehicle weight, Power and driver skill. Nasteboyii (Dan) pulled a 1.74 on the 225/50's this weekend in his PW/s car weighing 2400lbs. I personally hit 1.9's on average.
Why do people keep breaking Drivetrain parts? I'm on a complete OEM drivetrain and have been for years without any problems. Not even broken axles.
Phil
Old Sep 4, 2005 | 08:49 AM
Tippyman's Avatar
my rims now are 15" x 7". will the 225/50/15 fit the rim?
Old Sep 4, 2005 | 09:38 AM
JFK78's Avatar
Default Re: (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
What kind of clutch do you run? And no breakage ever even on slicks?
I'm wondering 'cause I've never broken anything either, and I run an ACT Xtreme PP w/ stock organic disc. My thinking is the organic disc doesn't engage harsh, so it doesn't shock the drivetrain.
Old Sep 4, 2005 | 09:46 AM
Rad Racing's Avatar
Default Re: (Tippyman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">my rims now are 15" x 7". will the 225/50/15 fit the rim?</TD></TR></TABLE>
Yes, they will fit VERY NICELY.
Old Sep 12, 2005 | 07:43 PM
JDMs1eeper's Avatar
Default Re: (JFK78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JFK78 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm wondering 'cause I've never broken anything either, and I run an ACT Xtreme PP w/ stock organic disc. My thinking is the organic disc doesn't engage harsh, so it doesn't shock the drivetrain.</TD></TR></TABLE>
same, I'm on autozone axles w/ stock dif. pulled a 1.70 several times, and a lot of 1.7xxx +
Old Sep 12, 2005 | 10:51 PM
ek9vboi2's Avatar
i've been hearing so much about these...just picked up a set of 14s (215/60-14) for my car. i plan to run them and hope i can get a nice 60ft. all my 60fts have been 2.29+, also i got omnipower coilovers...keep ya updated if i can pull anything off.
Old Sep 13, 2005 | 11:36 AM
TypeRPaul's Avatar
Making 181HP 128 TQ what size tires should i pic up, 205 or 225? also what size rims should i grab, i was thinking 15x7
Old Sep 13, 2005 | 12:06 PM
ek9vboi2's Avatar
i think 205 should be good considering the amount of power and tq u have. 128lb of tq will not really break out these tires. 15x7 rim if possible...wider is better. lol
here are the specs on these tires:
http://www.tirerack.com/tires/...FTADR
diameter for the 205/50-15 is 23" and the 225/50-15 is 23.9, so there is about a 1" diff in diameter
if ur car is all motor then the 205 should be good. boost or nitrious get the 225.
Old Sep 13, 2005 | 02:07 PM
TypeRPaul's Avatar
Default Re: (ek9vboi2)
great thanks for the info
Old Sep 13, 2005 | 07:35 PM
ek9vboi2's Avatar
HOLY SHIET! These tires are off the chain!!! I only took them for a test drive on the street and 2nd gear....no breaking out. Can't wait till track!
Old Sep 14, 2005 | 04:56 PM
nasteboyii's Avatar
Default Re: BFG Radials? (Tippyman98)
im selling a set of Nitto 555r's very little track time (never drivin on street) maybe 15-18passes, small boost (8psi) went 1203 at 121 hittin the rev limit at least 5 times (short gears) w/ 1.95 consistent 60s
want 200 shipped, thanks again guys
time for me to move up to big power/big tires
dan
Old Sep 15, 2005 | 08:34 AM
SPOOLED's Avatar
Default Re: BFG Radials? (nasteboyii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nasteboyii &raquo;</TD></TR><TR><TD CLASS="quote">im selling a set of Nitto 555r's very little track time (never drivin on street) maybe 15-18passes, small boost (8psi) went 1203 at 121 hittin the rev limit at least 5 times (short gears) w/ 1.95 consistent 60s
dan</TD></TR></TABLE>
TIRE SIZE?
Old Sep 15, 2005 | 09:03 AM
nasteboyii's Avatar
Default Re: BFG Radials? (SPOOLED)
yea sorry bout that 205 55 14s, i thought i posted that
i moved up to the 225 50 15s which is all i could fit under my car/ 235 are the biggest ucan run in PW/S trim
thanks
dan
Old Sep 16, 2005 | 03:49 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi2 &raquo;</TD></TR><TR><TD CLASS="quote">HOLY SHIET! These tires are off the chain!!! I only took them for a test drive on the street and 2nd gear....no breaking out. Can't wait till track!</TD></TR></TABLE>
keep us posted on your times, btw it's midnight madness @ moroso tonight
Old Sep 16, 2005 | 10:03 AM
ek9vboi2's Avatar
Default Re: (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">keep us posted on your times, btw it's midnight madness @ moroso tonight </TD></TR></TABLE>
I went wends, couldn't figure how to burn out properly (1st gear, lol). I talked to R@mon today after buying his clutch and he said roll over some water b4 hand...etc. I understand it now.
My 60ft were horrible....clutch was slipping x 2 I had my car ready too, installed omnipower coilovers (very nice btw), took out my system, etc. it was a bad day for me, but i beat a f150 lightning!
odd thing was it was slipping on the track, but on highway going home it was fine. i guess its the load taking off from a dead stop that made the clutch slip.
Old Sep 16, 2005 | 03:45 PM
smokey2.0's Avatar
do a second gear burn out, so that you can get them to heat up! just put it in 2nd, rev higher than 6K, and dump the clutch let them spin for a 3 sec count!
Old Sep 16, 2005 | 03:53 PM
ek9vboi2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">do a second gear burn out, so that you can get them to heat up! just put it in 2nd, rev higher than 6K, and dump the clutch let them spin for a 3 sec count!</TD></TR></TABLE>
will do. reason why i didnt do it at Moroso was b/c i had no idea how to do it and i didnt want to stall! lol...a red civic that ran 10s (ek) stalled, but he trapped like 130 going down the strip.
but yeah, i asked R@mon after buying his clutch how to do it and he explained to me. i'll keep you guy updated. 2.0 60ft is good enough for me.
Old Sep 16, 2005 | 05:19 PM
hondaguyef's Avatar
Default Re: (JFK78)
I am currently running a CM stage 3 (carbon kevlar disc/ stg. 3 PP). I've used the ACT xtreme w/ a steet organic disc as well w/ the same results. I also think that launch method has alot to do w/ drivetrain failure. I used to have an ACT unsprung 6 puck w/ Heavy duty PP in my NA B16 setup and would leave the line @ 8K+ rpm. This was before I learned to preload but, insetad of just dumping I let it out more gently (Just slower than simply sliding my foot off of the pedal) and would cut low 1.7 60 footers. Never had a drivetrain issue that way either.
Phil
Old Sep 20, 2005 | 08:40 AM
nasteboyii's Avatar
buy my drag radials so i can buy bigger more expensive toys, like multi stage boost
205 55 14s NITTOs 555r's in a 2350 lbs chassis 7-8 psi turbo hatch of course
1203 at 121 w/ that setup
dan
