Battery Switch Issue
Old Mar 14, 2011 | 08:53 AM
bigdgsr's Avatar
Default Battery Switch Issue
I have the battery relocated to the trunk. Running 6 gauge from starter to OEM fusebox, and then 2 gauge from OEM fusebox back to a distribution block. Off the distribution block I have 2 gauge to the kill switch with a 100 amp fuse and then a straight 2 gauge to the battery with a 100 amp fuse ( I set it up this way because it's still a street car, and I only need the kill switch for the track. If I pull the 100 amp fuse on the kill switch, then there is no power to the kill switch). I ran the alternator directly to the battery using 6 gauge with a 60 amp fuse. Problem I am having now is that I am seeing 14.3 volts at the alternator but on the alternator wire back at the battery I am only seeing 13.5. Should I switch to 4 gauge on the alternator wire? I've attached a quick diagram.
br8crumb
Jan 1, 2019 09:44 AM
84Riceeater
Feb 17, 2015 09:28 AM
EJ1B18c
Nov 14, 2008 11:52 PM
mrchris1979
Sep 3, 2006 01:30 AM
BLUE EH3
10
Aug 9, 2005 07:05 PM
