battery cables in or under from trunk?
Old Aug 27, 2006 | 11:23 AM
Slow00si's Avatar
Default battery cables in or under from trunk?
I'm building a car that needs to pass nhra and ndra ive relocated the battery in the trunk and ive mounted the kill switch but couldnt find anything in the rules about battery cable routing.
Right now ive got some of the thru panel connectors made by longacre, and i was going to put those through the firewall or is there a rule that they need to exit the car in the back and go under the car up to the front?
Post up what youve done that passes tech or what you might have heard, i would appreciate it.
Old Aug 27, 2006 | 12:07 PM
Slow00si's Avatar
Default Re: battery cables in or under from trunk? (Slow00si)
also anybody that has put them up front behind the bumper like tony1 can you show pics of how you routed the ic pipe around the battery
Old Aug 27, 2006 | 09:52 PM
redboost10's Avatar
a friend of mine that races super stock class at national events has his battery calbes for the kill switch and all that inside the car. this is nhra div 6
Old Aug 30, 2006 | 06:21 PM
ef_88_hatch's Avatar
you need to keep it all on side the car
Carol Martin
Honda Civic (2006 - 2015)
Mar 28, 2019 06:04 AM
apekd
16
Apr 10, 2009 10:34 PM
Hondasaurs
Aug 28, 2003 08:26 AM
turbo sol
Apr 14, 2003 10:48 AM
