b series engine dyno ???
Old Nov 17, 2010 | 10:03 AM
DaveF's Avatar
Default b series engine dyno ???
anyone know if there is a company that makes adapter pieces for this type **** or is it going to have to be "custom" made ?
Old Nov 17, 2010 | 10:06 AM
redboost10's Avatar
Default Re: b series engine dyno ???
superflow engine dyno, we are using a quicktime chevy bellhousing behind our b-series. doesnt matter which direction the dyno spins
Old Nov 17, 2010 | 10:09 AM
DaveF's Avatar
got pictures ?
what kinda flywheel setup are you using ?
Old Nov 17, 2010 | 10:12 AM
redboost10's Avatar
i dont have any pictures, sorry dave. stock sized flywheel/pressure plate but custom made by rob youngblood (advanced clutches).
Old Nov 17, 2010 | 10:16 AM
DaveF's Avatar
so the engine dyno "clutch:" piece bolts to the flywheel you had made ?
Old Nov 17, 2010 | 10:21 AM
redboost10's Avatar
yes, exactly. i believe its a chevy bolt pattern, basically uses the threaded holes where the pressure plate bolts up to if that makes sense.
Old Nov 17, 2010 | 10:34 AM
tony1's Avatar
Endyn is all setup for B series engines on their dyno, FWIW.
Old Nov 17, 2010 | 10:39 AM
redboost10's Avatar
dave, after tony's comment, i guess i should mention this is not a fwd application anymore so we are doing lots of "other" things hence the custom clutch/pressure plate combo and quicktime chevy bellhousing. you probably figured that out by now though, haha.
Old Nov 17, 2010 | 01:59 PM
xenocron's Avatar
I believe these guys have their engine dyno Setup for Honda Stuff too:
http://jkmotorsports.net/dyno.php
Old Nov 17, 2010 | 02:19 PM
Turbo-charged's Avatar
not positive but i think justice racing has a b series crap as well. all sorts of motec goodies and logging equiptment on their engine dyno.
Old Nov 22, 2010 | 11:36 PM
CNC HMA's Avatar
Mine is setup using a flywheel adapter and a modified bellhousing.
Howard
Old Nov 23, 2010 | 04:54 AM
HR-1320's Avatar
Howard
Do you have any pics?
raverx3m
Aug 12, 2015 06:04 PM
redboost10
Nov 13, 2006 06:52 PM
Fabman
Sep 21, 2006 07:40 PM
1999all_motoR_teg
10
Dec 5, 2004 07:28 AM
cpforyou
Jul 13, 2003 11:21 AM
