Aug fs thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
4) NO WTB ADS!
Kens Kustom wheelie/traction bars unused
cms racing spindle mount 15x4 make offer
franks fiberglass hot rod style 1pc front end-- make offer
P29 pistons and rings 100
**items for sale do not include shipping or pay pal fees**
I have a few things for sale pm me for more info.
600hp custom backdoor ic. precision core. 350
Gforce jacket 65 shipped
temp gauge no sensor gauge only. 25
boost solenoid 25 shipped.
new aem pressure sensor brand new 145 shipped
selling for a friend AEBS sleeved b18c5(integra type R block same as GSR) block is 84mm and needs to be cleand up to 84.5 to be ran block is bare no crank,matching caps.call or text him questions. mateen 586 260 7765 asking $$$700 for quick sale.
Up for sale is my 2.7L k24 long block built by 4Piston Racing. This motor has only been ran in the garage and on the dyno. Never been raced. Complete valve cover to pan.
The motor has the following :
-4Piston Pro 163 CNC head
-4Piston billet K600 single lobe cams
-Ferrea aluminum rockers
-4Piston valve springs
-4Piston valves
-ERL sleeved block
-Billet 106mm crank
-GRP Aluminum rods (4Piston spec)
-Wiseco pistons (4Piston spec) 16.5:1 CR
-ERL s2k oil pump
More detailed build specs and dyno numbers can be given to buyer.
$10,500 OBO
Also for sale is my Albins 4 speed helical dog box.
Trans has the following:
-Albins helical cut dog engagement 4 speed gear set, final drive, shift forks
1st gear : 2.55
2nd gear : 1.72
3rd gear : 1.32
4th gear : 1.08
Final Drive : 5.23
-MFactory LSD differential
-New OEM bearings thru out
This transmission was assembled by a certified Honda technician. Again this transmission has not seen track time. Only been on the dyno.
$6500 OBO
I am willing to separate the head and block. Also willing to sell just the gear set with out diff and case.
-4Piston valves
-ERL sleeved block
-Billet 106mm crank
-ERL s2k oil pump
$10,500 OBO
1st gear : 2.55
2nd gear : 1.72
3rd gear : 1.32
4th gear : 1.08
Final Drive : 5.23
$6500 OBO
706-346-6024
matt.stover@comcast.net
B18B Golden Eagle Block with Orings - needs to be bored to 85mm....the damaged cylinder cleared out just under 85mm so it will clearance out to your likings.
$800 OBO
Liberty's Gears 1st generation 3rd gear, countershaft side, 34 teeth, 1.36:1
I no longer need to keep it as a spare
$100 OBO
DH Racing 69mm Billet Throttle Body - has been cut, had a Vanjen Quick connector on it...still great for that or Vband
$150 with TPS - $100 without TPS
Set of 3 used Eagle rods - 5.430" length for B18C1 GSR Crank. $85
Set of 3 used manley rods - 5.430" length for B18C1 GSR Crank. $85
Built K24 Shortblock and Stock TSX Head.
Block: Machine work by CNC Engine Dynamics - Assembled by Mike at Charm City Tuning: 99mm crank, 87.5mm Custom CP 12.5:1 pistons with undersize wrist pins, Blueprint PRO-IBeam rods, CP 12.5:1 pistons. ACL Race STD HX sized bearings, soda blasted block, block deck machined
Head: TSX stock head with stock valve train and valve cover
Price: $3700 for all.
$3250 for short block
$550 for head
706-346-6024
Block pic
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768.
706-346-6024
$800 OBO
$100 OBO
$550 for head
706-346-6024
Block pic
706-346-6024
lenso with MT 24x8x13 tubes (fronts)
rear skinnies 24x4.5x15 asking 800
SOLD
white lenso with MT 25x8.7x13
price are only picked up will ship at buyers expense
SOLD
Endyn roller wave pistons for turbo app
10-1 comp
84.5mm
upgraded wrists pins $450 shipped
Hondata dealer kit for s200 brand new never used
comes with s200 with boost etc..
romulator and extras $400 shipped
10-1 comp
84.5mm
forsale, cleaning out all my b series parts.
gsr trans. MINT!! gsr 1-4th ls 5th, quaife diff,ls final drive brand new 2nd,3rd gears, new syncotech carbon lined syncros 1500$ or 2000$ with brand new m factory 4.0 final drive
m factory 4.0 final drive b series 550$
exady twin. 750$
aero a1000 fuel system 600$
ge b16 intake with rpm 70mm trottle body sold!
rays gram lights with tires, 2 almost new neo gens,2 50% falken 1500$
pro2 b series, new intake cam, exhaust has dyno time and 1 pass. 550$
2 t1 cam trigger kits, both brakets have been clearenced for turbos, 2 black cam gears with each kit, 400$ for 1 with full harness and 350$ for 1 with just a pigtail
custom speedfactory spec arias 1000+hp b16 pistons. 10.0 comp,600$
rear t bracket, new 60$
avid tq mounts,like new(bolted on car and took right back off. sold!
innovate 94a alum b series mounts,3 post 225$
aem v1 k series ems. 700$
gsr alum oil pan sold!
pit bike, sdg,110cc 4 speed,michelin moto tires,new plactics,decals,carb,tank been clocked doing 67 in a 35 and wasnt even close to maxing it out! 1500$ pick up only
welds with slicks, 10-12 passes 650$
other rims with slicks 500$
b series cop harness with cop plate 125$
b series id2000 harness pnp 100$
3" inline bov 100$
precision 750 intercooler needs new pipe welded on one side 300$
1 messes up gt4088r turbo. exhaust wheel ate up. 400$
1 messed up brand new t4 60-1 (center section got broke during shipping) 300$
endyn ported b16 head with crowler springs and retainers(needs valve seats) 450$
complete upr 79-93 mustang subframe,lower control arms,coil over sleeves rear anti sway bar. all parts brand new. retail 1100$ sell for 650$
LOTS of other parts, just message me anything you may need b series and i prob have it
K20A3 SWAP. pistons,rods,cnc ported head,all ferrea valve terrain,intake,6 speed trans,quaife,dss 2.9 swap axles,hasport mounts, dc/eg, carbonectics carbon carbon twin disc,aem v1 k series ecu,hybrid racing conversion harness eg/dc, engine harness,pre 1600cc inj,bdl fuel rail,sumped tank with all lines and eldebrock fuel pump,aero filters and all lines with elb regulator. will sell some stuff seperate. but want to sell engine and trans axles and mounts together. 7000$ with everything listed 8500$
also have a turbo kit as well i may sell if you want it. fullrace mani,750 pre intercooler,44mm wastegates x2, piping,bov ect
exady twin. 750$
3" inline bov 100$
Fs: Weld Racelite Import
4x100/114
13x8fr 15x3.5rr
24.5x8.5x13/22x3.5x15 M&H
Fronts are tubed, slicks are used but hooked on my car
Stupid light. Extra hardware included.
1200 shipped obo. Pm or email kandpperformance at gmail dot com
4x100/114
13x8fr 15x3.5rr
Located in Little Rock, Arkansas. Can ship TODAY.
I need to sell my Eagle 7/16 GSR rods. I spun a rod bearing on my old motor and bought a new one from Eagle. All will be balance at within a couple grams of each other and are in perfect shape. I put brand new rods bolts in the three old rods. $300 obo.
Motec m600 with utc,lambda control and advanced function and motec sdl backlight with 8mb datalogging and a slm shift light,looking for $6,800shipped OBO
F/S Used Arias 81mm bore B-series 9.0.1 compression turbo pistons and Eagle Rods for GSR motor all in great condition with plenty of life on them left. Might recommend new rings for someone who wants to make decent power on them. These pistons and rods came out of my running car which made around 600whp. (SOLD)
F/S Used Precision billet ball bearing 6765 turbo. The turbo is in great condition and has no issues what so ever. Could say "like new" 1000.00
-Borg Warner turbin housing Twin scroll 1.10ar for S400SX 71mm turbo. 125.00 New never used!
-Injector resistor box plus OBD1 injector clips. (USED)30.00
-MF2 Mappable Injector Driver can control either additional fuel injectors or water injection and 2bar map sensor. Instructions included (USED) Make an offer...
Selling some of my extra Sh_t before I move shops.
Black Kinsler 62mm Horns with adapters(can actually upgrade your 60mm wit this setup to bigger horn)
$250.00 (over $500 in retail)
Integra Steering wheel (came off our turbo Car)
$50.00
Custon CP Pistons that I ran last year
$500.00
RSX Altenator
$50.00
Hasport 95a inserts(Great upgrade for street cars)
$50.00
Racepak Kpro harness
$250.00
Integra GSR front spindles with 3.9 hubs
$300.00
All Parts are plus shipping and paypal fees
Marc P
$50.00
$500.00
RSX Altenator
$50.00
$50.00
$250.00
$300.00
Marc P
Selling my brand new SSR/DTR outlaw race header made for EG with a k24(built of course) with room to make more power with a bigger engine set up.exits out of the hood Paid $1400 selling for $1100 will ship at buyers expense someone come take it off my hands!
DOC top mount turbo T3 flanged 44mm manifold $750 Buyer pays shipping located in Portland OR please email or PM if interested.
Here's a pic of the manifold on the car, it has very good hood clearance!!
Clutch masters Twin disc clutch for D-SERIES!!!!!, like new used only a few pass's, asking $750+shipping PM me for more pic's
Innovative motor mounts 60a hardness used for less than 1000miles works for 92-95 civic or 94-01 integra asking $175 + shipping
K-series All motor hood exit stepped header done by GO-PWR Motorsports.. asking $1200 made 382whp+ with this header. It's a $1600 piece with a 8 weeks of turn around time if you order one. this is a must have for anyone doing a serious K build. just a little dirty but i can clean it up. exact lengths/specs can be given to serious potential buyers.
i also have other parts ill be posting soon. ex: ATI damper, Rywire milspec 8 injector set up, CM twin disc clutch/flywheel, PAR dog box, 2 sets of 750cc/1000cc GO-PWR ID injectors, VC and catch can set up with all black nylon and all AN fittings, Port Flow head, etc etc..
