April FS Thread
3 piece front end brand new never installed $1200 willing to deliver or u can pick it up at Honda day and if I bring it on honda day I will have to receive a deposit via PayPal showing me that the buyer is serious. Delivery only goes as far as Maine,Vermont, New Hampshire, Massachusetts, Connecticut, New York, Jersey
text me at 617 719-1781 that is the best way to get in contact with me
For sale sleeved h22a1 89mm bore 50mm mains 800obo
Crower stage 3 cams h22 $400
Located in Maryland will ship buyer pays shipping and paypal fees text me at 9149793782
Trades
S300 and cash
Turbo
44mm wastegate
Large fmic
Skunk 2 pro 2 for h22
Kpro
Bseries twin disk
Kseries twin disk
Trades
S300 and cash
Turbo
44mm wastegate
Large fmic
Kpro
Bseries twin disk
Kseries twin disk
Selling my turbo kit decided to upgrade before i even start the car the kit will consist of turbo,manifold,wastegate,intercooler,dumptube,uppi pe
Precision 6766 t3 .82a/r $1000
Precision 46mm wastegate $300
Nitro performance top mount $700
3 1/2 inch uppipe $150
Under the car dumptube $75
Afi dual backdoor intercooler $500
Asking $2200 shipped as a package deal!
EVERYTHING IS BRAND NEW NEVER HAD AIR/OIL/BOOST GO THROUGH ANY OF IT!
Also selling my laskey built short block Again everything is brand new! Laskey built b18c Benson sleeves 84mm Cp 10:3 pistons Pauter rods Ati street dampner Arp headstuds $3500 Edelbrock victor x b16 flange with skunk2 74mm throttle body with vibrant vajen $400 Id 2000s $750 golden eagle fuel rail $100
-Hondata s300 in p28-$400
-InlinePro SS cast t3 mani-$100
-misc B series distributor parts-$80
-4.9 FD unknown brand good shape-$200
-Prosport digital blue wideband wire chaffed but fully funstional-$80
*** I do NOT check pm's***
Call or text me at 334-7six3-O927
Will accept PayPal. Add the fees or send as gift. Will ship everything.
909 728 5033 Joel
$1100 w/ core exchange $1450 w/out. ( LS CORES NOT ACCEPTED FOR THIS OFFER )
click images to enlarge
*REMAN* JDM 95-97 ITR JDM 92-00 SiR/CTR US 92-95 Delsol Transmission
This reconditioned manual transmission. Fits all B-series Honda/Acura 92-01 Hydro ( Hydraulic Transmissions ) 0 miles since rebuild
GEAR RATIO
1st 3.230
2nd 2.105
3rd 1.458
4th 1.107
5th 0.848
R 3.000
FD 4.400
NON-LSD
NEW
Case Tumbled & Cleaned ( oem type satin finish )
1-2 Sleeve
1st Friction Ring
2nd Friction Ring
3-4 Hub & Sleeve
3rd Gear
5/r Sleeve
Carbon Synchros
All new bearings
All new seals
Nite Grind Plaque
GEAR RATIO
1st 3.230
2nd 2.105
3rd 1.458
4th 1.107
5th 0.848
R 3.000
FD 4.400
NON-LSD
NEW
1-2 Sleeve
1st Friction Ring
2nd Friction Ring
3-4 Hub & Sleeve
3rd Gear
5/r Sleeve
Carbon Synchros
All new bearings
All new seals
Nite Grind Plaque
I have a few things to clear out before it goes on eBay. I'm negotiable, but no lowballers.
H22 Valve cover powder coated black chrome, two -10an, and two -6an bungs welded on, earls proflo 300 lightweight braided hose, all earls fittings, catch can made to bolt in the factory charcoal canister location, removable coolant surge tank included with hose. Comes with JDM Honda oil cap. Plug and play breather setup. $425 shipped
H22 tucked wire harness. Not fully loomed but is routed and extended to where any visible connector is loomed, heat shrinked and labeled. Alt wiring has aerospace fire sleeving. Injector clips are labled but bare pins so they will plug into whatever plugs you need. Local shop built it for me. $450 shipped
Skunk 2 can gears, never adjusted, under 1000 miles, like new. $125 shipped
AEM TruTime can gears, used but in good shape. $110 shipped.
Innovative H22 alt relocation bracket, used for mockup only $85 shipped
Time to part with my rsx. Its a 2003 acura rsx-s with 45K miles on it garage kept and well taken care of. The setup has around 3k miles on it and makes very good power
500whp on 93 pump 93
650whp on c16
730whp on e85 on a old setup
-Block
k20
erl 2.1
cp 10.5:1
carrillo rods
ported polish head
ferrea comp valves
brian crower stg 3 cams
ported hayward manifold 80mm tb
-Turbo kit
full race t3 sidewinder w/ twin 44 gates
6765 82ar
3 inch dp and exhaust
24x12x4.5 intercooler
3 inch pipes
-Trans
ep3 5 speed
tilton cmc
exedy twin disk
-Fuel
id2000
c16
walbro 450lph
-ecu
aem ems2
mac 3 port
aem 3.5 bar map
aem boost,oil pressure,temp gauges
-Wheels/Tires
volk sf challenge
245/40/18 bridgestone re50a runflats
asking 18,000obo can text me at 7852264100 if you have any questions. serious buyers please
650whp on c16
-Block
k20
erl 2.1
cp 10.5:1
carrillo rods
ported polish head
ferrea comp valves
-Turbo kit
6765 82ar
3 inch pipes
-Trans
ep3 5 speed
tilton cmc
exedy twin disk
-Fuel
id2000
c16
walbro 450lph
-ecu
aem ems2
mac 3 port
aem 3.5 bar map
-Wheels/Tires
volk sf challenge
I hate to have to go in this direction but due to some changes in my life I have to get rid of one of my cars. So with that I decided to part out my drag car. I have bought and sold lots on here so buy with confidence. I can provide numerous vouches if you require. All prices are shipped and in US dollars you must pay paypal or send as a gift. I am located in Canada but do not let this stop you from buying. Do not bother lowballing me I will completely ignore them. If you don't like the prices feel free to buy elsewhere.
Text or PM only 1 306 551 5139
- Race motor brand new never used - $4000 shipped (Does not come with valve cover $200 more for that) *WILL NOT PART OUT. SOLD AS A WHOLE*
Benson sleeved LS-vtec engine (sleeved prior to benson engraving the block)
84mm bore
GRP billet aluminum rods
Custom ross 11:1 pistons w/gas ports
JE custom wrist pins
O-ring'd block and reciever grooves in the head
SCE Copper head gasket
Moroso 5qt oil pan
JG cylinder head GSR
cnc'd
ferrea bronze guides
JG .5mm oversized flat face valves
JG valve springs and retainers
fresh valve job and surface
Highly polished front of cylinder head looks amazing
Brand new skunk2 pro 1 camshafts
- B series PAR Dog Box Gearset 2.9/2.0/1.4/1.09 With a 4.4 Final drive and cuff support maybe 10 passes with brand new M-Factory Diff installed in a re-endforced case - $5000 shipped
Chase Bays CM1 Engine Harness - Honda/Acura B / D / H Series CHASSIS: 92-95 Civic | 94-01 Integra ECU/ECM: OBD1 INJECTORS: ID-2000 ALTERNATOR: OBD0/OBD1 IGNITION TYPE: OBD1 Distributor - $500 shipped
AIR Carbon Fiber intake manifold(Fits both gsr and b16 heads dual bolt pattern) - $950 Shipped
B series Carbon Fiber Valve Cover - $500 shipped
B series Oil Catch Can, Comes with valve cover, 4 lines(2 for head and 2 for block), and oil catch can - 400 shipped
Sprinwerks Slicks and Skinnies *WILL NOT SPLIT THESE UP DON'T ASK*
Fronts are 26x10x15 with bead lock(4x100 bolt pattern)
Rears Skinies are 25x4.5x15 (4x100 bolt pattern)
$1500 Shipped
Fuel System - 900 shipped
- 2x Bosch 044 with relays
- -8an Feed and return braided lines
- 5 gallon fuel cell
- Precision GT4294 journal bearing, 4" V-Band . Rated for up to 850hp, small chip in one fin *see picture* - $700 shipped plus paypal
- Garett 950hp Dual Back door intercooler(core size is 3.5"x12"x24") with 3" piping flanged for a tial 50mm BOV- The outlet piping on the front mount was squished a bit during shipping when I received it. This set up is used. - $550 shipped
- 4" Aluminum exhaust for EG Hatch, 3" vband with clams, one spot was cut for shipping purposes and will have to be re-welded or put a new vband clamp on it. There is a dent on the tip of the muffler from shipping. $400 shipped (please note the exhaust is not properly lined up for the picture
- KOYO aluminum Rad with 12" mishimoto fan and hoses with Rad cap (ALL BRAND NEW) $400 shipped
- RPM 72mm throttle body - $120 shipped
- 2.5" steel cold side piping with clamps NO BOV
Front mount intercooler roughly 20"x9"x3" (made 475hp no problem) - $150 ship will not split this up
- AZ racing GSR Girdle - $80shipped
- Eg traction bar (garage built so not the nicest) - $100 shipped
- J's Racing CF air Duct for EG (passenger side) -$125 shipped
Sorry for not having my name in all the pics. I recently packaged everything up to move but can take better picks for people who are only seriously interested. The only different from the parts now compared to when I took these pics are they are now in packaging ready to ship.
84mm bore
Moroso 5qt oil pan
cnc'd
$1500 Shipped
I'm selling my AFI B series intake manifold because I'm changing my setup.
I paid well over 1200 for this manifold, and waited a good bit for it. Its a 3.7 Liter Plenum and Tapered runners, 90MM TB opening and it'll come with the fuel rail bolt setup, for free.
Does not include fuel rail or TB. I'm looking for 800 shipped OBO.
I've had a lot of interest on Facebook with this manifold but nobody's came through to buy, it is on the car, but I can have it off and shipped within a day.
Email: Derek @ DDTECHCAMS.com
Cell: 225-384-onefourfourone
Have a few extra fuel cells I'm looking to sell. Two 5.5 and two 7.5 gallon cells that fit in the stock location. plan on welding on -8 feeds and a -6 return, but can do different if you buy before I weld them. neck and fitting for the stock filler neck will be added as well, just waiting on the materials.
$350 plus shipping located in akron, ohio
pm me or call/text 4404528759
http://hondamarketplace.com/attachme...3&d=1396094725
GSR HP racing intake manifold 270.00
Top speed racing t3 ramhorn manifold with tial 44 wastegate flange with 3" down pipe 680.00
4" ceramic coated down pipe for sx400 turbo and topmount manifold 250.00 ALL PARTS ARE USED REASONABLE OFFERS WELCOMED.
Up for sale 95mm eagle crank for b-series $350 obo does not include shipping PM or text 516-729-4760. Thanks
image share
image share
TESTING WATERS: for sale my 95mm complete shortblock, this went 10.41 @130 mph and had more in it but i built a bigger motor. i can see this little motor going a .30 once properly dialed in. this shortblock was freshend up by randy owens over this winter so everythign is fresh and brand new. it has new main and rod bearings, new thurst washers, fresh hone and pistons rings. its ready to rock. the motr consists of the following
JDM CLOSED DECK H22A
ERL SLEEVES
KS TUNED BALANCE SHAFT DELETE
NEW OIL PUMP
CARILLO H22 LENGTH RODS
CUSTOM CP PISTONS (MAX DOME/MAX COMPRESSION)
BRAND NEW OEM USDM NON VTEC PRELUDE CRANK 95MM
for more info contact me at 516 342 0318 im located in long island, ny
ERL SLEEVES
NEW OIL PUMP
