---April FS Thread---
Item: 2 tial wastegate 38mm mv s
Price: $225 each
Contact: 786 236-6751
Item Description: i have 2 brand new mvs wastegates purple 38
Photos:
Price: $225 each
Photos:
EK hatch with NHRA Certified Chromoly 8.50 cage... Turn key race car
$11,800 obo
http://hondamarketplace.com/showthread.php?t=3041190
$11,800 obo
I got my old W2A for sale. It has help me run 8.90's mph 174.......It has a precision core rated for 1000hp.....I'll try to post a copy of one data log where it was hot out so you could see how good my inlet temps were. It could be 100+ and temps still under 60 degrees 1st and second gears! I have run over 55psi with this set up and have had no problems! Turbo manifold also for sale....You'll need very little fab if this is going into a eg/dc.........
For tank with pump,pipping,and ic I'm asking 750.00 plus shipping
Turbo Twin t4 manifold I'm asking 700 plus shipping
RR Connecting aluminum Rods(b18b/a) with Acl race(hx) bearings(std) drilled by RR (std pin size)asking 600 shipped obo
Credit Cards are accepted, paypal, or direct deposit into Chase Bank........
You need any more info call me at 210-214-8542 or email me at
jjfury1@GMAILDOTTTTTcOm
I have a Motec harness for any Honda and Acura. It was made by Motec all Milspec. It also comes with the modified dist. done by Motec. $800 It can be used with any M4 or M48.
I also have a harness just like this one but done by a diy customer of mine which is for sale for $400.
$100 shipped
Turbosmart 38mm wastegate. packaged and ready to ship. best means of contact is email at Kenbdsi@gmail.com thanks
Email -- James@IPGParts.com
Phone -- 407-324-4684
We have an enormous amount of awesome used Drag Racing Parts available
way too much to post here
here is a Text Only List that we generated to start with -- http://www.ipgparts.net/blog/general...learing-house/
and here are some of the great highlight parts
-- Mark Williams Axle Kit for 92-00 Civic, 94-01 Integra (Spindle, Brakes, Axles, Intermediate Shaft) — $2800
-- MB Racing Fiberglass Doors for 92-95 Honda Civic (includes lexan, latches, etc) — $600/pair
-- Nuformz Rear Spindle Mount Suspension with Strange Coilovers for 92-00 Civic, 94-01 Integra — $1800
-- Bogart Wheel for Nuformz Rear Spindle Mount Suspension Setup — $750
-- Penske Front Coilover for 92-00 Civic, 94-01 Integra, Remote Reservoir, Drag Valved — $1375
-- GM 4T65 Auto Race Transmission with K Series Adapter Plate and 2nd Mockup Transmission Case — $2900
-- Precision 6265 Journal Bearing Turbo, T4, 0.81 A/R, S Cover — $775
-- Weldon 2015 Fuel Pump — $495
-- Bogart 15×10 Double Beadlock Drag Wheels with Dunlop 28x10x15 Tires — $1200
-- Z10 B Series Wet Sump Oil System -- $750
-- Used IPS - Hayward Performance 8 Injector K Series Intake Manifold with TB -- $1200
and the list goes on, and on, and on -- check it out here -- http://www.ipgparts.net/blog/general...learing-house/
Dart block 84x89 manley/cp 9:1 compression built to handle 1000whp........5000
pm for details
Nrg tech billet case.............................................. ............................sold!!!!
4 inch aluminum exhaust for ek,dc,eg...burn stainless muffler all vband.......700
s2000 cr seats with dc2 rails .................................................. ...........1100
perrin intercooler for evo 9....fits usdm dc2 perfect.................................500
s2000 cluster no pigtails.......................................... ...........................150
pm for details
This is a complete package. Motor, EMS, Gauge, Turbo. Quality parts used. All parts are Brand New Never Used
Serious Buyers only. Total spent on this build is $15,753.
Buyer pays actual shipping cost.
Cash, PP Gift or you Pay 3%
Long Block $7400
Motor is a B18C Built by ERL Performance
-Manley H-beam Rods
-Wiesco Coated Skirt 8.5:1 Pistons
-ERL Superdeck Sleeves
-ARP Headstuds
-ARP mainstuds
-Moroso 5 qt pan with bungs for turbo drain and temp sensor
Oil Pump, Oil Pickup, Water Pump Timing belt. New Bolts used throughout whole engine. New water pipes, thermostat housing, all new gaskets seals All OEM Honda parts
Cylinder Head- Integra Type R head
-Integra Type R Camshafts
-M factory Camgears
-Supertech Valvesprings and Titanium retainers
-Supertech nitride coated valves
- New valve seals, Cam cap bolts, valve guides, cam seals all OEM Honda
Turbo setup- $2200..... retail $2650
-Topmount manifold with 3" 5 bolt downpipe
-Precision SC61 6152SP Turbo
-Precision 46mm Wastegate with several springs
Edelbrock intake manifold with AEM Fuel Rail Injector Dynamics 1000cc Injectors. 70mm Throttle body new OEM TPS sensor, Hondata 4 bar map sensor
EMS- $790
-Hondata S300 with Electronic Boost Control
-AEM Wideband sensor
Block also has 2 10AN fittings on the back for a breather setup
Long Block $7400
-Manley H-beam Rods
-ARP Headstuds
-ARP mainstuds
-M factory Camgears
EMS- $790
Shipping included only for lower 48
Hydro B series –EF Avid Pro Race Solid Motor Mounts SOLD
Avid EF B series shift linkage SOLD
MMR EF chassis fiberglass front end $250 picked up.
Prostock carbon fiber CRX rear hatch $150 (very very light)
Stock GSR cams $75.
D series Alternator with Aem Underdrive pulley $50 shipped
DC sports D Series 4-1 Stainless header $150 Shipped
1991 CRX Chassis SOLD
Stock GSR cams $75.
Seat Brace $20
remote kill switch $60
parachute release stuff (sold)
Contact
Brian.Afflerbach@gmail.com or PM
Location
Allentown(ish), PA
Contact
Location
Allentown(ish), PA
A few items for sale all are in good working condition if not new. Prices negotiable.....
-Borg Warner turbin housing Twin scroll 1.10ar for S400SX 71mm turbo. 125.00 New never used!
-Injector resistor box plus OBD1 injector clips. (USED)40.00
-TiAL new 60mm inlet flange. (NEW)25.00
-35mm Exhaust flange plus gasket. (NEW)10.00
-MF2 Mappable Injector Driver can control either additional fuel injectors or water injection and 2bar map sensor. Instructions included (USED) Make an offer...
**USED** M&B 1 Piece (WIDE)Fiberglass Front end for 88-91 Civic with mounted hardware.
Im looking for local pick up, but may consider shipping to lower 48 states only!
Seller: Thomas
Contact: jdm894g@aol.com or text: 424-230-6503
Price: $200 No Trades, may negotiate price!
Seller: Thomas
Contact Info:
jordan holland
whipple ohio
740-629-4669
Parting a few things out
First up Competition Clutch Twin disk clutch for b series with the matching flywheel has alot of life left, about 8k miles on it. $500 clutch was orig 1350..
NEXT is my moroso oil pan and pick up, ONLY trade for stock GSR only windage tray, oil pan and pick up and cash.... This is a gsr only oil pan and pick up.. And will need stock gsr parts in return... $200 + stock parts
Ek AVID solid motor mounts- $200
GSR trans, liberty face plated gears, Mfactory LSD, liberty Cuffed, CARBON 1-4 synchros.. I'll do $1000 and a stock GSR or B16 trans thats in perfect shape.. Has to be cable
jordan holland
whipple ohio
740-629-4669
i have brand new in box blox drag full suspension
all 4 front and rear
12k 18k springs
for 92-95 civic or 94-01 integra may fit other models with modifications
if u dont know about these coilovers go to blox site read about them
almost exact replica of omni drag
i paid 675 i have reciept i want 675 obo
there 700+ new online + shipping from MOST SITES u find em for less then 675 shipped ill match that price and u can get em from me same day
i paid less then 7 cuz i bought a few sets in bulk
text w interest 443 798 4419
12k 18k springs
p28 hondata s300 ready to go.... 600
bnib h22 distributer(internal coil)...100
Mint Skunk2 pro2 cams and aem cam gears...440
port/polish h22 Head fresh out the machine shop... 850
3 angle valve job
DH racing valve springs retainer
stock valves
new oem valve seals
powder coated gunmetal valve cover
AEM fuel rail (silver)... 80
RC 750cc injectors...200
New RMF replica Headers(modified for h2b)...400
new CX racing radiator with 12inch Spal fan...100
h22 block/h23 crank.... 2200
sleeved,88mm wiesco 13:1 pistons with new rings h23 95mm std crank micropolish and balance crank acl rod bearings clevite mains SGI h-beam rods
h23 single crank pulley
new oem oil pump/rear main seal
balancer shaft deleted
rota 15 slipstreams powder coated glossy black..380 no tires
3inch eg exhaust with 3inch magnaflow tip(looks like polish vibrant muffler).... 200
u can contact me at 305 281 6495 ryan
3 angle valve job
stock valves
new oem valve seals
I'm Located in IL.
Dart 84 MM short block Std block Under 100 miles
Cp pistons 9:1
LS crank
LS Pauter Rods
ACL Bearings
Golden Eagle Head Studs
All new Honda bolts, seals, Oil pump, Water pump,T-stat housing, ETC.....
Toda T-Belt
ATI Damperner
-10 Fittings in the block and B&R plug, one -6 fitting for coolent in the front.
New oil pan with -10 fitting.
$3900.00 OBO
CC twin disc for Hydro B-series used for under 100 miles. $1000.00 OBO plus paypal and shipping
98 LSD GSR Hydro trans, comes with slave cyl, sensors, and shift linkage. Around 60,000 miles. No pop-outs, grinds, or shifting problems.
$700 OBO
Email Turboc1@sbcglobal.net for more info or pictures.
Would like to try and not ship. I will Deliver or meet depending on were.
I'm Located in IL.
Cp pistons 9:1
LS crank
LS Pauter Rods
ACL Bearings
Toda T-Belt
ATI Damperner
$3900.00 OBO
$700 OBO
