Anyone using Co2 on kpro
I know the way boost control is through kpro is different than s300 how do you you setup the Co2 to work with kpro bbg? What regulator psi are people running off the bottle.
I'm talking about using co2 for boost control to put psi on the gate. I'm wanting to change to a smaller spring but won't be able to run the psi I want up top without it. I know guys with s300 use it often but kpro doesn't have a few options in boost control like s300 does.
Using C02 will work.
Ok thanks. Be carefull in what means? What psi should the regulator be set to then? It gas to be a bit more than the psi your wanting to run max correct?
Pumpking.
Feb 3, 2012 10:31 AM
Yep, just remember that C02 has alot more pressure then just using boost, so be careful with it.
