Any idea??????
Old Mar 17, 2007 | 03:18 AM
harhoosh's Avatar
Default Any idea??????
Took the car to the track last night for Test & tune and broke the clutch again , I Also broke one last month in the T & T after 4 pass only.
Hear the Pic from last month:
[IMG][/IMG]
Old Mar 17, 2007 | 03:25 AM
DaveF's Avatar
Default Re: Any idea?????? (harhoosh)
do you have all the bolts holding the pressure plate to the flywheel ?
Old Mar 17, 2007 | 03:46 AM
harhoosh's Avatar
Default Re: Any idea?????? (dturbocivic)
Yes, I run only one fine pass with the ACT and got 11.02 in the morning, but in same day after noon the gear would't go into 2nd, so when i open it i saw that.
Old Mar 17, 2007 | 04:02 AM
DaveF's Avatar
were all the bolts torqued to spec?
Old Mar 17, 2007 | 10:25 AM
harhoosh's Avatar
Yes sir.
Old Mar 17, 2007 | 10:35 AM
Clayton's Avatar
H-T Administrator
25 Year Member
My first thing would be to try to contact ACT, that's a strange break
Old Mar 17, 2007 | 10:36 AM
velocitytrends's Avatar
how does the clutch feel when you engage and dis-enage it before the clutch took a dump?
Is the motor a stock motor/crank?
What were your torque specs and was your torque wrench calibrated?
Is it a stock pressure plate, ACT pressure plate? Was there any damage anywhere else, ie. pilot bearing , flywheel and so on?
Old Mar 17, 2007 | 10:39 AM
Default Re: Any idea?????? (Clayton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clayton &raquo;</TD></TR><TR><TD CLASS="quote">My first thing would be to try to contact ACT, that's a strange break</TD></TR></TABLE>
It is a strange break, yet I have seen alll kinds of carnage from many clutchs out there. ACT will just ask him to send that one in and probably replace it, but that was on the first one. Being that its now 2 that have done the same thing it wouldn't be the clutch disc. Something else is wrong.
Old Mar 17, 2007 | 10:51 AM
harhoosh's Avatar
I contact them already and they told me returne it to them but its not worthey (300$ returne charge from my country).
Old Mar 17, 2007 | 11:02 AM
harhoosh's Avatar
Default Re: (velocitytrends)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocitytrends &raquo;</TD></TR><TR><TD CLASS="quote">how does the clutch feel when you engage and dis-enage it before the clutch took a dump?
What were your torque specs and was your torque wrench calibrated?</TD></TR></TABLE>
It feel normal when the car is cold, but after one run its feel hard to shift from gear to another and some time its stuck in one gear.
My motore B20 buttom and B16 head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Is it a stock pressure plate, ACT pressure plate? Was there any damage anywhere else, ie. pilot bearing , flywheel and so on?</TD></TR></TABLE>
Toda ultralight flywheel, ACT xtrem P.P & ACT 6 pad unspring disk.
Old Mar 17, 2007 | 02:38 PM
allmotorh22's Avatar
Default Re: (harhoosh)
I had the same problem with my act clutch. If you figure out what it is let me know
Old Mar 17, 2007 | 03:11 PM
melovesboost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harhoosh &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like you got a Bent Shift Fork in the trans
Old Mar 17, 2007 | 06:04 PM
Dragline's Avatar
Default Re: (melovesboost)
Is it possible to put that disk on backwards?
Old Mar 18, 2007 | 06:48 AM
Default Re: (Dragline)
ive never had success putting a clutch disk on backwards.. but i have seen a few built Backwards
Old Mar 18, 2007 | 09:06 AM
harhoosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melovesboost &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like you got a Bent Shift Fork in the trans</TD></TR></TABLE>
After i removed the ACT clutch, I put exeady clutch kit S1 and the gear was shifting fine but its slipping with nitrous.
So, i think there is no problem with the trans.
Old Mar 18, 2007 | 09:08 AM
harhoosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dragline &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to put that disk on backwards?</TD></TR></TABLE>
No way to put the clutch backward, cuz the hup will touch with the flywheel.
reboosted
Oct 4, 2009 07:56 PM
hayabusa160
Jun 18, 2008 01:28 PM
DragSource
May 26, 2005 05:57 PM
AllMoToRB18c
17
Nov 22, 2004 05:55 AM
EGhybridHB
Jan 5, 2004 06:17 PM
