Another question regarding suspension setup?
Old Jul 19, 2006 | 07:49 AM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Another question regarding suspension setup?
Looking to buy a good setup for my EG. I am wondering what most of you SFWD guys are using? I already searched and have only came up with Skunk2 drag springs, which I am not interested in. Omni Power's drag setup which seems okay, but I don't seem to see a whole lot of people using it. I already have used Ground Controls with my selected spring rates with race valved Koni yellows and like it but would like more adjustability. I am considering the Progress units but people seem to not be able to afford them so I can't seem to get a good legitimate response. If someone can give me a solid answer I would appreciate it. Thanks to you guys in advance.
Old Jul 19, 2006 | 10:31 AM
Default Re: Another question regarding suspension setup? (JDMThoughts)
wow.. no one has an any advice on this matter.
Old Jul 19, 2006 | 10:41 AM
tony1's Avatar
I run Omni's drag setup. Seems to be working ok for me.
Old Jul 19, 2006 | 10:52 AM
ranta18's Avatar
What rate springs do you have now (front and rear)?
300-500 fronts and 900-1100 rears should work fine with good shocks, a front traction bar, and good 24.5" slicks. I don't see why you couldn't cut at least a 1.6x with that.
Old Jul 19, 2006 | 11:10 AM
AllMoToRB18c's Avatar
Default Re: Another question regarding suspension setup? (ranta18)
D2's here ..great coil over i love em
Old Jul 19, 2006 | 11:40 AM
DC4_MADMAN's Avatar
I am also loking into this for my DC.
I WAS going to go with the the Strange double adjustibles with hypercoils, but if I can find a cheaper alternative that will work as good as or close to , Id go that route.
Old Jul 19, 2006 | 12:16 PM
vaporboy12's Avatar
Default Re: (4door_demon)
omni cheap and it works
Old Jul 19, 2006 | 12:43 PM
underpressure02's Avatar
Strange
Old Jul 19, 2006 | 06:20 PM
I have 10K in the front and 16K in the rear of my GSR. I love the setup, but the adjustibility of the Koni's isn't enough for me. I don't mind spending money, but this is really for a street car, so I don't think the Strange's are going to be needed.
Tim are the D2s in your hatch, and if so what kinda 60fts do you get with them. Another question of note is what are the spring rates?
Old Jul 19, 2006 | 06:28 PM
tony1's Avatar
What do you think you need adjustability wise that the koni can't offer?
Old Jul 19, 2006 | 06:35 PM
DaveF's Avatar
dont let the guys in the suspension forum hear you "shitting" on koni's, they'll have your head
Old Jul 19, 2006 | 06:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMThoughts &raquo;</TD></TR><TR><TD CLASS="quote">Tim are the D2s in your hatch, and if so what kinda 60fts do you get with them. Another question of note is what are the spring rates?</TD></TR></TABLE>
yes the D2's are in my hatch...next time you see me at an event you can come check them out...im not sure what the spring rates are...my best 60ft. was a 1.62 but i usually pull mid 1.6s...hopin for 1.5s next time out ...and they are very affordable
Old Jul 19, 2006 | 06:49 PM
FMUNK's Avatar
Default Re: Another question regarding suspension setup? (dturbocivic)
Tho Omnipower suspension works great.
That is what I reccommend
Old Jul 19, 2006 | 08:03 PM
DC4_MADMAN's Avatar
Default Re: Another question regarding suspension setup? (FMUNK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FMUNK &raquo;</TD></TR><TR><TD CLASS="quote">Tho Omnipower suspension works great.
That is what I reccommend </TD></TR></TABLE>
Omni power doesnt have the drag setup listed on their website. What are the front and rear rates and wheres a good place to get em?
Thanks
Old Jul 19, 2006 | 08:05 PM
HYBRID_H@TCH's Avatar
Default Re: Another question regarding suspension setup? (4door_demon)
I have omni's in my ride to..10K front 12K rears...
Old Jul 19, 2006 | 08:15 PM
DC4_MADMAN's Avatar
Default Re: Another question regarding suspension setup? (HYBRID_H@TCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRID_H@TCH &raquo;</TD></TR><TR><TD CLASS="quote">I have omni's in my ride to..10K front 12K rears...</TD></TR></TABLE>
Pardon my retardedness, but what would that be in #s?
Old Jul 20, 2006 | 05:24 AM
TurboEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon &raquo;</TD></TR><TR><TD CLASS="quote">
Pardon my retardedness, but what would that be in #s?</TD></TR></TABLE>
12kg/mm = 671.969 lb/in
10kg/mm = 559.974 lb/in
8kg/mm - 447.979 lb/in
Old Jul 20, 2006 | 05:27 AM
TurboEM1's Avatar
Default Re: Another question regarding suspension setup? (TurboEM1)
all the people that recomend and run omnis for drag...
what spring rates are you running?
and is it a track only car?
I currently have omnis and i have a pair of 8k, 10k, and 12k springs and im not sure what combo to use. Car is DD and a drag car running mid 11's. Its a CRX so its fairly light so i dont think i have to go crazy stiff. What do you think would be good but still streetable/safe to drive on the roads?
Old Jul 20, 2006 | 08:19 AM
ranta18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMThoughts &raquo;</TD></TR><TR><TD CLASS="quote">I have 10K in the front and 16K in the rear of my GSR. I love the setup, but the adjustibility of the Koni's isn't enough for me. I don't mind spending money, but this is really for a street car, so I don't think the Strange's are going to be needed.</TD></TR></TABLE>
Thats around 560/900 and with the Koni's you should be good. What 60fts are you getting now? Do you have a traction bar? What size slicks? You'd probably be better off keeping the shock/spring combo how it is and spending money elsewhere to go faster.
Modified by ranta18 at 7:05 PM 7/21/2006
Old Jul 20, 2006 | 06:08 PM
Wrong info listed on my part, I have 900lb springs in the front on my Ground Controls and 1200lbs springs in the rear on my Ground Controls. The Ground Control/Koni setup I am talking about is in my GSR. I have an EG I am working on. I get 2.0 60fts on ES100s and I also have a Full-Race traction bar installed on my GSR.
DturboCivic I am not shitting on my setup, and if people in the road race/suspension forum get mad, oh well. I like the setup, it's really nice for auto-x and is a good setup on the strip. I also spent like 1000 on the re-valved Koni shocks. I figured I would see what would be good and if possible cheaper. If I need to copycat the same setup and use it on my EG then I will. I figured I would gauge the information I could get.
I plan on picking up another Full-Race traction bar for my EG as well, and swap all bushings out. Will adding or deleting a sway bar on the car help me as well?
Tim, I will make sure I stop by to talk to you at HondaDay, your going right?
Old Jul 21, 2006 | 04:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMThoughts &raquo;</TD></TR><TR><TD CLASS="quote">Tim, I will make sure I stop by to talk to you at HondaDay, your going right?</TD></TR></TABLE>
yes i will be there...but ill also be at the Nopi event next week at Atco...if youre goin there you can stop by
Old Jul 21, 2006 | 10:47 AM
Default Re: Another question regarding suspension setup? (AllMoToRB18c)
Won't be at Atco, but will hit you up at E-town.
PS What are the rear spring rates you guys with the Omni Power coilovers using?
Old Jul 22, 2006 | 07:36 AM
redboost10's Avatar
i have the omni drag setup, mine are 18k rear and 12k front. make sure to balance the car with you in it also.
Old Jul 23, 2006 | 06:22 PM
Default Re: Another question regarding suspension setup? (tgh99si)
Cornerweighting is going to be the last thing I do, but it is already on the list of things that need to be done before the car gets driven around
JDM809
Suspension & Brakes
Jul 11, 2011 12:18 PM
Luke J
Suspension & Brakes
49
Feb 2, 2005 08:40 PM
AllMotor4ever
Oct 6, 2004 04:53 PM
VTECJUN
Sep 4, 2004 08:11 AM
bomber
Jul 23, 2004 04:20 PM
