Aerodynamics
Old Jan 2, 2003 | 04:31 PM
nfiedler3's Avatar
Default Aerodynamics
How important is aerodynamics in the 1/4 mile or is it more for top speed? As far as lowering, front air dam, and rear function spoiler...?
Old Jan 2, 2003 | 08:00 PM
rYduckz's Avatar
Default Re: Aerodynamics (nfiedler3)
top speed is affected considerably more by aerodynamics than lets say a 1/4 mile. but in a the 1/4 aerodynamics still do play a role
Old Jan 2, 2003 | 09:40 PM
nfiedler3's Avatar
Default Re: Aerodynamics (FastNSX)
How important is aerodynamics in the 1/4 mile...?
There are a couple of aspects to this question. First, less drag = more speed at the same hp and weight. How much of an effect this has is going to depend a primarily on how fast you are gong. My friend's back-half Camaro hits 150 mph by the end of the eighth mile, so it is obviously a factor in his 1/4 mile trap. It may or may not be in yours.
Second, aerodynamics play an important part in the stability of the car at the big end. Better aerodynamics mean less wandering, less scary stuff.
Third, aerodynamics can play a part in gaining traction, espicially for a RWD car. Once the car is going more than 60 mph or so, a wing can ad considerable downforce.
So, to answer your question: it depends.
Thanks...you know your ****...now go have a couple
Old Jan 2, 2003 | 10:07 PM
Toad's Avatar
as long as your aerodynamics isnt just a wing....yeah it would affect your 1/4
if your going to do a wing......do it right....goto jspamerica.com JSP is #1 rated in every wing contest to see which creates the best downforce
I personally use there new blade wing which is made out of carbon fiber and only weights 6 pounds.....plus gives me the downforce i need...
Old Jan 3, 2003 | 01:35 AM
nfiedler3's Avatar
Default Re: Aerodynamics (Toad)
go away...
Old Jan 3, 2003 | 04:43 AM
Mista Bone's Avatar
D Tranny Guru
well, I removed one piece of plastic and went .3 second faster. That peice was the rear bumber cover and car was D15B7 powered.
Old Jan 4, 2003 | 01:30 AM
Mista Bone's Avatar
D Tranny Guru
2.1 mph
cksnah252
Aug 12, 2015 06:40 AM
B20vEf9
31
Jan 6, 2011 06:51 AM
austrian type-R
May 19, 2002 11:13 PM
AlphaKennyWun
May 10, 2002 03:14 AM
CRXRageD
May 6, 2002 08:27 AM
