Advice on Drag Radials
Old Jun 25, 2003 | 09:39 PM
JiggyKooAndy's Avatar
Default Advice on Drag Radials
I am looking at the Nitto 555r's. What size should i get, and where should i get them?? Any other suggestions on tires as well? Please include size.
Old Jun 25, 2003 | 09:43 PM
J2turbo21's Avatar
Default Re: Advice on Drag Radials (JiggyKooAndy)
What size rims do you got?
Old Jun 26, 2003 | 01:43 AM
iH8RICERZ's Avatar
Default Re: Advice on Drag Radials (J2turbo21)
the nitto 555's are ok imo, i'd recommend looking into other drag radials before making a sure decision.
Old Jun 26, 2003 | 02:26 AM
Downey's Avatar
get some BFG's. i hear they are better than Nitto 555R. Ask Austin, hes had lots of experience with 205/45-15 555R and now hes gonna be using 205/50-15 BFG
Old Jun 26, 2003 | 10:02 AM
Austin's Avatar
Default Re: Advice on Drag Radials (Downey)
I've only had 5 learning runs on the BFG tires, and well over 200 runs on the Nitto tires...best 60" for me on the nitto tires were a 2.107, so far on the BFG I've run 4 2.2X and 1 2.1X, but I'm still playing with the tire pressures and launch RPM...I need to hit up a good test and tune section.
Austin
Old Jun 26, 2003 | 10:08 AM
RTW DC2R's Avatar
Default Re: Advice on Drag Radials (Austin)
BFG gForce Drags they are on my list of things to get soon. very sticky, and good enough to get you to and from the track.
Old Jun 26, 2003 | 10:15 AM
AllMotorDC2's Avatar
Default Re: Advice on Drag Radials (RTW DC2)
I agree. The gForces hook unbelievable for a street tire.
Old Jun 26, 2003 | 10:22 AM
Georgethefierce's Avatar
Default Re: Advice on Drag Radials (AllMotorDC2)
1.95 60' on BFG's 205-50-15's on steelies in a 3166lb. Prelude
'nuf said buy them, run them, love them
edit: 16lbs. front 42 rear stock potenzas
Old Jun 26, 2003 | 10:24 AM
AussieK24's Avatar
Unfortunately I'm stuck with Nittos. Austin: Did you kind an ideal tyre pressure for your setup???
Old Jun 26, 2003 | 10:47 AM
PM-Performance's Avatar
BFG's are the **** , when you go to a big event and BFG is there, ask to use a set , they will let you for free, 1st run on thme i went 1.9 60ft without even pushing it too hard.
Old Jun 26, 2003 | 11:10 AM
Default Re: Advice on Drag Radials (itr206)
ok i'm gonna get the BFG g-Force T/A's in 205/50/15. I'm just wondeirng if i should get them on steelies becuase they won't drive at all in the rain...or do they grip somewhat well in the rain???
Old Jun 26, 2003 | 11:19 AM
GO 225 50 15 or 215-50-15 i forget the size off hand, trust me ,more sidewall = more traction
Old Jun 26, 2003 | 11:29 AM
RTW DC2R's Avatar
make sure you get the gforce T/A drag radials, and not the COMP T/A radials... there is a difference so make sure you order the right ones.
Old Jun 26, 2003 | 11:31 AM
the comp t/a are for the rwd cars, and yes there is a big diff , i haev used both.
Old Jun 26, 2003 | 12:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JiggyKooAndy &raquo;</TD></TR><TR><TD CLASS="quote">ok i'm gonna get the BFG g-Force T/A's in 205/50/15. I'm just wondeirng if i should get them on steelies becuase they won't drive at all in the rain...or do they grip somewhat well in the rain???</TD></TR></TABLE>
i don't run them on the street so i can't say but I use Honda CRv 15" Steelies (smallest ones that'll fit over the calipers)
Old Jun 26, 2003 | 06:27 PM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">the comp t/a are for the rwd cars, and yes there is a big diff , i haev used both. </TD></TR></TABLE>
Although, some turbo guys on here do use the Comp T/A's due to lack of larger sizes with the g-Force.
I've driven the g-Force in mild rain before, going 75-80 mph on the highway. But I wouldn't recommend it. Hydroplaning is not fun.
JDM_EJ8
Oct 23, 2012 03:39 PM
umair
Jan 10, 2011 07:26 AM
Jsarv
Jul 23, 2008 07:55 AM
EdBoon
Jul 28, 2005 11:51 AM
SlicksMH
Dec 12, 2004 05:38 PM
