Advantage On Weight Of Chassis?!?
Old Mar 23, 2006 | 07:20 PM
kidd_drastic's Avatar
Default Advantage On Weight Of Chassis?!?
I'm shooting for 240 whp and 160pounds of torque with my b series project. I was wondering the weight advantage on an EG and EK hatch. Does any know the weight of a full interior eg hatch without driver and the weight of a full interior ek hatch without driver? Also how drastic will the time slips be between the two in the quarter mile considering both with same mods, same driver, etc.
Old Mar 23, 2006 | 08:03 PM
SpeedDreamz.com's Avatar
Default Re: Advantage On Weight Of Chassis?!? (kidd_drastic)
I think there is about 150lbs difference fully loaded.
Old Mar 23, 2006 | 08:46 PM
Default Re: Advantage On Weight Of Chassis?!? (SpeedDreamz.com)
how about gutted without ac, power steering, ect. Is there much of a difference? also with 150 pounds difference how does that affect the quarter mile time?
Old Mar 23, 2006 | 10:40 PM
Supernatural's Avatar
i would say that 100 lbs is good for a tenth.... but sometimes weight in the right areas will do wonders as well
Old Mar 23, 2006 | 10:46 PM
ImportMotorSpec's Avatar
Default Re: Advantage On Weight Of Chassis?!? (Supernatural)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supernatural &raquo;</TD></TR><TR><TD CLASS="quote">i would say that 100 lbs is good for a tenth.... but sometimes weight in the right areas will do wonders as well</TD></TR></TABLE>
Yes they say 100 lbs equals a tenth.
Depending on where the weight is is a big factor. Lets take the sunroof for example. Say you put a plug in it that saves 35 pounds. That weight is off the highest point in your car. Now take say your A/C off and thats 35 lbs. That is about mid/low car. Take a 10lb weight and run with it at waist level, very easy. Take that same weight and attach it to a 3 ft pole and try to run, a lot harder to get going. Hope that explained it, makes sense to me...
It all has to do with center of gravity
Old Mar 23, 2006 | 11:07 PM
Default Re: Advantage On Weight Of Chassis?!? (ImportMotorSpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportMotorSpec &raquo;</TD></TR><TR><TD CLASS="quote">
It all has to do with center of gravity</TD></TR></TABLE>
but does a lighter chassis always equal a faster time?
Old Mar 24, 2006 | 02:37 AM
b20turboic's Avatar
YES ... but again if you add weight to a light chassis in the right spots it could be faster.
Old Mar 24, 2006 | 02:41 AM
Default Re: Advantage On Weight Of Chassis?!? (b20turboic)
amazing. Does anyone know the weight difference in a GUTTED eg and GUTTED ek. By gutted i mean no ac,power steering, rear seats panels all the way to the back hatch.
Old Mar 24, 2006 | 08:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidd_drastic &raquo;</TD></TR><TR><TD CLASS="quote">amazing. Does anyone know the weight difference in a GUTTED eg and GUTTED ek. By gutted i mean no ac,power steering, rear seats panels all the way to the back hatch.</TD></TR></TABLE>
a gutted eg with no driver i would say is 1900
Old Mar 25, 2006 | 08:27 AM
efboy's Avatar
what you want is as least rear weight as possible and really stiff rear springs. when you launch and when you shift, weight is naturally going to tranfer to the back which sucks for front drive, cause drive wheels are up front. the springs in the back will stop some of that weight transfer. you can figure every 100 lbs equals a tenth added to your 1/4. if your so worried about weight get a crx
Old Mar 25, 2006 | 11:42 AM
Default Re: Advantage On Weight Of Chassis?!? (efboy)
weel i was deciding between a ek and eg. Just wondering what the weight difference is gutted.
Old Mar 25, 2006 | 12:04 PM
with all thing remaining even it would stand to reason that they would still be approximately 150lb different. I dotn know if an ek seat weighs more than an eg seat, etc .
Used2beAb16's Avatar
What sucks is the EK's just look so much better.
Old Mar 25, 2006 | 12:51 PM
Default Re: Advantage On Weight Of Chassis?!? (Used2beAb16)
150 pounds is not bad at all if you use the theory off adding 1 tenth of a second for every 100 pounds. unless you hit 13.14 in an ek
Old Mar 25, 2006 | 05:08 PM
trecool44's Avatar
My track experience has shown that in out light cars, 100 pounds can mean 2 tenths. Its happened to me many times. This year im racing my turbo b16 del sol, so ill really be hurting.
Old Mar 25, 2006 | 11:40 PM
1 2 NV's Avatar
Default Re: Advantage On Weight Of Chassis?!? (trecool44)
i found 100lbs=2/10ths in my car. but then eventually you get into the land of diminishing returns and then 100lbs=1/10th. my biggest thing with weight off the car was driveline parts tended to be more reliable.
Old Mar 26, 2006 | 04:07 PM
lohatch's Avatar
Default Re: Advantage On Weight Of Chassis?!? (1 2 NV)
in a EG hatch with 150whp a 120lb addition added 2 tenths (.2x) to the ET
3 times in a row.
so the less power you have the more it shows up
EFstyle
Jun 15, 2006 09:03 PM
msinsky14
36
Jan 10, 2006 04:21 AM
Hondog
Jun 5, 2004 07:29 PM
Almypal
Mar 10, 2004 12:43 PM
juiced96hatch
Sep 11, 2002 02:23 PM
