Adjustable 2 step options....
Old Jan 30, 2008 | 04:38 PM
misterpsycho's Avatar
Default Adjustable 2 step options....
I'm just looking around for adjustable 2 step options for my new build.... the car will be tuned on crome (ya, i know there's better out there but that's what i'm using)
So, my question is.... what are my options in terms of an adjustable 2 step system? I'm looking to have something i can adjust between runs if i need to
This will be used on a mild NA car....
Old Jan 30, 2008 | 07:03 PM
mrbsponge's Avatar
i have an MSD Digital6 i love it, i use to have an older 6AL and i hated it, but the digital has an adjustable limter in increments of 100, and can retard timing up to 9 degrees while on the limiter
Old Jan 30, 2008 | 07:21 PM
SOHCinWA's Avatar
I also use a Digital6.... Both of my cars... 2step is simple and easy.
Old Jan 30, 2008 | 07:23 PM
Default Re: (SOHCinWA)
that's what i was thinking.... either a digital 6 or digital 7.... but i just wanna know if there's other options out there other than an msd ignition box or hondata/neptune/etc
Old Feb 1, 2008 | 03:15 AM
Newt Dog's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">i have an MSD Digital6 i love it, i use to have an older 6AL and i hated it, but the digital has an adjustable limter in increments of 100, and can retard timing up to 9 degrees while on the limiter</TD></TR></TABLE>
Damn, I did not know this. How much boost are you able to make on 2-step with the ignition retarded 9 degrees??
Old Feb 1, 2008 | 01:23 PM
94turboeg's Avatar
Default Re: (Newt Dog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newt Dog &raquo;</TD></TR><TR><TD CLASS="quote">
Damn, I did not know this. How much boost are you able to make on 2-step with the ignition retarded 9 degrees?? </TD></TR></TABLE>
Old Feb 1, 2008 | 01:45 PM
h22crxpwr's Avatar
Default Re: (misterpsycho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misterpsycho &raquo;</TD></TR><TR><TD CLASS="quote">that's what i was thinking.... either a digital 6 or digital 7.... but i just wanna know if there's other options out there other than an msd ignition box or hondata/neptune/etc</TD></TR></TABLE>\
crome has a 2 step feature. not as easy to change it between runs unless your tuner is at the track. but it works pretty good on my NA setup... unless you know how to work with crome then you can change the 2 step yourself at the track.
Old Feb 4, 2008 | 11:39 AM
Default Re: (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">crome has a 2 step feature. not as easy to change it between runs unless your tuner is at the track. but it works pretty good on my NA setup... unless you know how to work with crome then you can change the 2 step yourself at the track. </TD></TR></TABLE>
yeah, i've used the 2 step feature in crome... not really a big fan cause all you can do is guess where you'll launch at best, and if it's too low you're screwed and will just bog every god damn time!!! (yeah, it happened to me)
and, like i said, i need something adjustable
Old Feb 4, 2008 | 11:53 AM
h22crxpwr's Avatar
and, like i said, i need something adjustable</TD></TR></TABLE>
i know an affordable way would be to use the MSD 6AL with the 2 Step on a button.
Old Feb 4, 2008 | 11:56 AM
h22crxpwr's Avatar
i know an affordable way would be to use the MSD 6AL with the 2 Step on a button. </TD></TR></TABLE>
or you can just remove the 2 step feature in Crome and go run it at the track. then whatever RPM you find that you get the best 60' then program that as your 2 step in Crome.
Old Feb 5, 2008 | 11:03 AM
.nate's Avatar
eCtune and neptune both has on the fly ajustable launch control... No need for a laptop or anything else...
Old Feb 5, 2008 | 11:18 AM
h22crxpwr's Avatar
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">eCtune and neptune both has on the fly ajustable launch control... No need for a laptop or anything else...</TD></TR></TABLE>
how do you adjust it? with no laptop?
Old Feb 5, 2008 | 01:20 PM
civicxpress's Avatar
GET AN AEM.... spend the money and less the headache
you can change the 2 step after every run yourself its simple.
2step settings change all the time depending on the weather, track conditions, ect..
Old Feb 5, 2008 | 01:28 PM
h22crxpwr's Avatar
Default Re: (civicxpress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicxpress &raquo;</TD></TR><TR><TD CLASS="quote">GET AN AEM.... spend the money and less the headache
2step settings change all the time depending on the weather, track conditions, ect..</TD></TR></TABLE>
i don't have any headache running crome right now. N/A car and works great.
however someone stated that the ECtune launch control can be adjusted without the use of a laptop. so i'm asking how that can be done???
Old Feb 5, 2008 | 02:55 PM
exactly my point u cant use it!!
NOT USER FRIENDLY= "HEADACHES"
then when you get it setup, u wont be able to change it again!!!
like i said conditions change all the time which means you need to change your setup also!!
AEM = NO HEADACHES
AEM ALL THE WAY BABY
Old Feb 5, 2008 | 07:42 PM
i'd love to go with an AEM EMS but i just don't have that kind of money to spend right now....
and don't you still need a laptop to change settings on the AEM unit?
Old Feb 5, 2008 | 07:43 PM
SOHCinWA's Avatar
An MSD Digital6 will cure all that
Old Feb 10, 2008 | 12:03 AM
Civic89stdB16's Avatar
from what ive heard ectune's 2 step can be changed by holding the gas at the desired 2step rpm then stroke the throttle. it sets the 2step at that desired rpm. its that easy. thats just what ive heard. lmk if im right.
Old Feb 11, 2008 | 05:43 AM
.nate's Avatar
That is correct, you gently rev the motor to where you want to launch from and then go WOT. The rev limit is set there. To change it just repeat the process, rev it up and go wide open where you want to launch from...
Old Feb 11, 2008 | 06:05 AM
Default Re: (.nate)
what other software has the ajustability other than ectune. anyone know. does chrome or neptune offer this. thanks
Old Feb 11, 2008 | 06:58 AM
logg_frogg's Avatar
Look to MSD for sure, they offer all sorts of add on ignition controls and the like! as well as full on units like the digital6.
As far as the digital 7 goes, stay away from it if you don't know what you're doing really well. The instruction manual reads like an engineering text lol!
Old Feb 11, 2008 | 10:47 AM
.nate's Avatar
Default Re: (Civic89stdB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 &raquo;</TD></TR><TR><TD CLASS="quote">what other software has the ajustability other than ectune. anyone know. does chrome or neptune offer this. thanks</TD></TR></TABLE>
Read my first post again:
layedoutat0psi
13
Nov 20, 2007 12:34 PM
ganjafarmer143
17
Oct 4, 2006 03:40 AM
pip9
Jul 28, 2004 05:06 AM
Captn. Save A Hoe
Nov 15, 2003 12:58 AM
MugenGTR
Mar 31, 2003 01:38 PM
