Adding Weight for traction
Old Mar 31, 2008 | 12:17 PM
1junkycivic's Avatar
Default Adding Weight for traction
Does adding weight in street cars up front help with traction ya or na?
Old Mar 31, 2008 | 12:31 PM
MrParks's Avatar
Default Re: Adding Weight for traction (1junkycivic)
yes it does, but adding wieght up front isnt going to reduce your et's without making adjustments.
ie: corner balance, tire pressure, camber,toe,and caster, not to mention valving for your shocks and spring rates.
Old Mar 31, 2008 | 12:56 PM
NativeSon's Avatar
Default Re: Adding Weight for traction (MrParks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrParks &raquo;</TD></TR><TR><TD CLASS="quote">yes it does, but adding wieght up front isnt going to reduce your et's without making adjustments.
ie: corner balance, tire pressure, camber,toe,and caster, not to mention valving for your shocks and spring rates. </TD></TR></TABLE>
Yes. People easily forget its all the little things that add up to getting good ET's.
If this was easy, it wouldn't take 150 mph to run a 9 second ET, lol.
Old Apr 1, 2008 | 01:04 PM
Default Re: Adding Weight for traction (NativeSon)
If it was the answer no one will tell.Secerts are never told.Anyone else wants to chime in?
Old Apr 1, 2008 | 01:15 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1junkycivic &raquo;</TD></TR><TR><TD CLASS="quote">If it was the answer no one will tell.Secerts are never told.Anyone else wants to chime in?</TD></TR></TABLE>
It's a give or take situation. You need to dial it in.
Adding weight will make you slower, but if you add it in the right places will help with traction and make you faster. Adding weight also breaks driveline parts, just ask the SFWD Kseries guys.
It's different for every car and every setup, so you get to play with it.
Edit: Ha, I just read the keyword there. "Street car." The key to having traction on the street is pretty simple. 300whp, big BFGs, traction bars, boost by gear, and save the real power for the track.
baboracus
Suspension & Brakes
Mar 22, 2007 04:29 PM
24boosted
Honda Civic (2006 - 2015)
12
Mar 2, 2007 11:46 AM
Mordeki
Suspension & Brakes
Jan 15, 2007 01:36 PM
rleonekc
Jul 10, 2006 10:23 PM
nek9
Jun 13, 2006 11:08 AM
