adding weight, to a car. how did you do it?
Old Mar 23, 2005 | 05:56 PM
smokey2.0's Avatar
Default adding weight, to a car. how did you do it?
guys for the nhra class, that i would like to compete in i'm about 150LBS too light. if in the past you have been in the same senario, my question is how did you add the weight(following nhra rules)? where did you buy the materials? and if you have pictures of the weight added, please post them TIA. btw this weight addition, will be done in my 88crx!
Old Mar 23, 2005 | 06:00 PM
1FSTHATCH's Avatar
As I was told by the director you could bolt lead weights directly to the frame.. In the case of your car i would have each corner of the car weighed and i'd balance it with distributing the weight across the car..
Good luck too you..
Pickle
Old Mar 24, 2005 | 12:15 AM
smokey2.0's Avatar
Default Re: (1FSTHATCH)
i have seen kits, that would help you do that. but very little info, about those products is availabe(or i just can't find it).
Old Mar 24, 2005 | 12:30 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (smokey2.0)
Well if you dont have exhaust, add it. put on the stock hood other than CF or fiberglass. Add a ballast would be the best way tho.
Old Mar 24, 2005 | 05:33 AM
jdkindle's Avatar
bags of lead shot......or putting lead shot in rails and the bolt the rails where you want them
Old Mar 24, 2005 | 05:36 AM
DaveF's Avatar
Default Re: (jdkindle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdkindle &raquo;</TD></TR><TR><TD CLASS="quote">bags of lead shot......or putting lead shot in rails and the bolt the rails where you want them</TD></TR></TABLE>
keeping it low as possible.
on dirt track cars, we used to get pieces of 2x3 rectangle shape tubing, weld one end closed, than fill it with lead, and weld the other end shut. drill holes in it, than bolt it down.
Old Mar 24, 2005 | 07:38 AM
blackmagicCRX's Avatar
Default Re: (Dturbocivic)
don't you want to put as much of the weight over the front wheels or at least in front of them???
Old Mar 24, 2005 | 10:46 AM
THE BEAST's Avatar
Default Re: (blackmagicCRX)
If it was me and I was in that position and had a little time:
I would find where you want to add the weight. Put the car on independent scales (each tire having its own). fyi..I would then balance out the front end then work my way to the rear. On front wheel drive cars its obvious that you want to have weight in front of or above the front wheels.
Now do something similar to above. Get some steel pipe and weld one end closed then cut out the hole for the other end from sheet metal. Now get an old pot from the thrift store and buy some lead shot. Put the pipe and the cap (so you can account for that weight also) where you want the weight and find out how much lead shot you need. Then go over to your outside grill and melt the lead shot in the pot. Go over to the pipe and fill it with the pre-measured lead shot. Weld the cap on the pipe and your done.
I have seen in some old school drag cars where they would drill a hole in the cage bars and pour it into the cage piping so that you dont see it. I think this is not a legal way of doing it in any of the sanctioning bodies...but its worth asking them!
Good luck
Old Mar 24, 2005 | 04:11 PM
smokey2.0's Avatar
Default Re: (THE BEAST)
guys, thankx for all your advice. i might take my car to a truck scale tomorrow, to see how much weight i will need to add. i have done as much possible, to keep the weight as far foward as posible. bigger wheels, heavier seats, etc... i'll have to ask people at work, where can i find the lead pellets!
Old Mar 24, 2005 | 06:43 PM
JL's Avatar
JL
Default Re: adding weight, to a car. how did you do it? (smokey2.0)
fast food might help
i was trying to find pictures of JGTC ballast weight, no luck. what about getting a bigger battery? what exactly have you done that has put it underweight?
Old Mar 25, 2005 | 12:43 AM
smokey2.0's Avatar
Default Re: adding weight, to a car. how did you do it? (JL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL &raquo;</TD></TR><TR><TD CLASS="quote">fast food might help
i was trying to find pictures of JGTC ballast weight, no luck. what about getting a bigger battery? what exactly have you done that has put it underweight?</TD></TR></TABLE> the car began its life under weight, remember it's a 88 crx with a b swap. i'm already 240LBS lol, i don't really want to gain any more weight
Old Mar 28, 2005 | 06:02 PM
smokey2.0's Avatar
i have put everything that i can on the car, except for the heater core and the front bumper support wich i just don't have. i'll be weighing the car tomorrow, at a local weight station near my job. if you guys have any pictures of how you did put on weight, please post them
Old Mar 28, 2005 | 08:27 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">i have put everything that i can on the car, except for the heater core and the front bumper support wich i just don't have. i'll be weighing the car tomorrow, at a local weight station near my job. if you guys have any pictures of how you did put on weight, please post them </TD></TR></TABLE>
this is how gardella did it on his previous car.
Old Mar 28, 2005 | 11:42 PM
smokey2.0's Avatar
Default Re: adding weight, to a car. how did you do it? (Dturbocivic)
hey thankx for the picture, i was thinking of using something like that. i just never pictured those steel bars, with 1/2 bolts through them. i'll see what the car weights by 11am, and i'll make some decisions after that!
Old Mar 29, 2005 | 11:50 AM
h22 civic's Avatar
i like the way vinny ten used to do it ..............45 pd weider plates in the back
Old Mar 29, 2005 | 03:32 PM
smokey2.0's Avatar
Default Re: adding weight, to a car. how did you do it? (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">i like the way vinny ten used to do it ..............45 pd weider plates in the back </TD></TR></TABLE>i might have to go that route, i went to the scales and the car weights 1940LBS. with me in it, it will hit 2180lbs leaving me with a 170LBS deficit i have three days to get this done
Old Mar 29, 2005 | 04:30 PM
DIRep972's Avatar
Smarter than you
I thought the NHRA minimum was 2400? you need 220lbs.
Old Mar 29, 2005 | 04:36 PM
h22 civic's Avatar
Default Re: adding weight, to a car. how did you do it? (DIRep972)
Old Mar 29, 2005 | 05:29 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">I thought the NHRA minimum was 2400? you need 220lbs.</TD></TR></TABLE> good thought, but if you check the rule book on line. go to page 25
4 cyl 2350lbs minimum weight
6 cyl 2650lbs minimum weight
Old Mar 29, 2005 | 05:41 PM
E-Town4229's Avatar
sadly thats been my plan.
anyway i would see what you can load up where the bumper support was.
-Roger
Old Mar 29, 2005 | 06:04 PM
smokey2.0's Avatar
Default Re: adding weight, to a car. how did you do it? (E-Town4229)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Town4229 &raquo;</TD></TR><TR><TD CLASS="quote">
-Roger</TD></TR></TABLE>
i'll be taking off the bumper off tomorrow night, to see what i can do with that space!
Old Mar 29, 2005 | 07:46 PM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote"> good thought, but if you check the rule book on line. go to page 25
6 cyl 2650lbs minimum weight </TD></TR></TABLE>
Oh damn, did not realize you were running street stock! I just ***ummed sport fwd. good luck
racinskittle's Avatar
Default Re: (Bean-Burrito)
dead bodies
Old Mar 29, 2005 | 08:09 PM
DragSource's Avatar
I have no experience with this, but if I was in a similar situation, I might:
1. Remove bumper support
2. Fill it with sand
3. Weld sheetmetal over holes and gaps.
4. Re-install bumper support
and if that doesn't cover the full amount you need to lose, you could put something under the carpet. . . heavy and flat. . . roof shingles perhaps, lol.
Old Mar 30, 2005 | 04:54 AM
Gravy's Avatar
Default Re: (DragSource)
hey luis i can bring the car up to the weight!!! lol but u wouldnt have this problem if u were turby......
