act clutch
Old May 14, 2006 | 06:18 PM
s4yama's Avatar
Default act clutch
Any body got an opinion on an act maxx extreme kit with a 6 puck disc for racing only? got a boosted ls/vtec.
Old May 14, 2006 | 06:50 PM
1fastgsrturbo's Avatar
Default Re: act clutch (s4yama)
i have a boosted coupe making 600+ and I blew the clutch up after about 6 passes on 25 inch slicks, lauching @9k. The only reason why I had the 6 puck was b/c I wasnt planning on making the power i am making. In my opinion, go to a twin disk if your planning on making any high whp numbers and if your not try your luck with a 6 puck
Old May 14, 2006 | 06:51 PM
stickyfingers's Avatar
depends how how much hp you are making, may hold up for some time if hp numbers are about 400 ish. twin disc is the way to go for high hp numbers.
Old May 14, 2006 | 07:02 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: act clutch (stickyfingers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickyfingers &raquo;</TD></TR><TR><TD CLASS="quote">depends how how much hp you are making, may hold up for some time if hp numbers are about 400 ish. twin disc is the way to go for high hp numbers.</TD></TR></TABLE>
i was thinking the twin as well.
Old May 15, 2006 | 12:09 AM
s4yama's Avatar
Default Re: act clutch (boostedcivicsir)
Thanks for the info. any suggestions on what brand twin disc to use. Hopefully i will be making at least 500 hp. maybe more if i'm lucky.
Old May 15, 2006 | 04:08 AM
Mr. Badwrench
tiltons are picky, no exp with CM twins, i have an exedy twin and love it.
Old May 16, 2006 | 04:48 PM
PHDZINE's Avatar
Default Re: act clutch (1fastgsrturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastgsrturbo &raquo;</TD></TR><TR><TD CLASS="quote">i have a boosted coupe making 600+ and I blew the clutch up after about 6 passes on 25 inch slicks, lauching @9k. The only reason why I had the 6 puck was b/c I wasnt planning on making the power i am making. In my opinion, go to a twin disk if your planning on making any high whp numbers and if your not try your luck with a 6 puck </TD></TR></TABLE>
Thats probably why you blew the clutch...9k lauches are pretty high.
I probably under estimated the Maxx extreme clutch but i haven't blown mine out yet. If I had a bigger budget I probably would change it out for an Exedy twin but as of right now I'll cross my fingers and see how much more abuse this clutch can take.
With my Maxx extreme clutch set up I'm lauching on the 2 step at 7200 RPM's with 25-8.7-13 M&H, shifting @ 9300 RPM, 1.65 60', 1/8 mile @ 113 MPH and 10.31 in the 1/4 mile @ 146 MPH and I make 787WHP and 535 TQ on a T72 Innovative turbo 38psi. Still getting the suspension and traction issues taken care of.
I think it really depends on your driving technique on how fast your clutch slips. I personally preload the drive-line when I launch.
Old May 16, 2006 | 05:01 PM
boostfeen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
i was thinking the twin as well.</TD></TR></TABLE>
...Exedy
Modified by boostfeen at 4:47 PM 5/23/2006
Old May 16, 2006 | 05:06 PM
ninesecrx's Avatar
Default Re: act clutch (boostfeen)
I made a bunch of 9 second passes with this exact clutch. At this time the car was on Gasoline making 675whp. We used 26x9 inch slicks. Once we went to 28's...I had issues and went to the RPS twin disc which worked awesome.
Old May 16, 2006 | 07:55 PM
22psicrx's Avatar
Default Re: act clutch (ninesecrx)
I have 24" slicks launching at 7000rpm using my 2 step with the actextreme and 6 puck clutch. However i'm just learning stock b16a2 w/10 psi. 270WHP. 60FTS ARE AT 1.72. I have done 25 runs. The clutch is good for what I am using it for. Torque holding power is 400 ftlbs at the crank so I'm safe. What are your plans.
Old May 17, 2006 | 08:19 AM
PHDZINE's Avatar
Default Re: act clutch (22psicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22psicrx &raquo;</TD></TR><TR><TD CLASS="quote">I have 24" slicks launching at 7000rpm using my 2 step with the actextreme and 6 puck clutch. However i'm just learning stock b16a2 w/10 psi. 270WHP. 60FTS ARE AT 1.72. I have done 25 runs. The clutch is good for what I am using it for. Torque holding power is 400 ftlbs at the crank so I'm safe. What are your plans.</TD></TR></TABLE>
I believe that the torque capacity on the MAXX EXTREME clutch set is 487 FT/lbs at the crank
Old May 18, 2006 | 09:33 PM
s4yama's Avatar
Default Re: act clutch (PHDZINE)
does'nt the maxx extreme pressure plate put to much pressure on the crank causing the thrust bearings to wear out way to fast?
Old May 19, 2006 | 12:22 AM
808 NA1's Avatar
If you plan on making big power, just buy a good twin disk clutch like Exedy or Tilton. ACT's are good and sorta cheap, but they wear pretty fast on a daily driver. Maybe not so bad for you because its a race only car, but still you cant compare an ACT to a Tilton or Exedy. I went through three ACT Extremes on my car. Now I have an Exedy twin. I will never buy another ACT again. BTW I still have my old ACT clutch and streetlite flywheel if you would like to buy it. I would sell it cheap.
Old May 19, 2006 | 09:15 PM
alphaek's Avatar
all depends on the power of ur motor
Old May 22, 2006 | 06:13 PM
boostfeen's Avatar
..this weekend at ATCO, we had a brand new ACT six puck in Kory's coupe
and it lasted ONE effin pass! one pass and it was toast. even the guys at the ACT booth saw it and said wtf. So i def. do not recommend a six puck if your makin over 600hp. get that twin disk...
Old May 22, 2006 | 07:22 PM
vtekthis's Avatar
tilton's suck
Old May 22, 2006 | 07:29 PM
Professor15's Avatar
Default Re: act clutch (vtekthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">tilton's suck </TD></TR></TABLE>....lol personal expeirence?
Old May 23, 2006 | 12:48 PM
boostfeen's Avatar
..i think i like the way Exedy sounds more & more everyday
Old May 23, 2006 | 12:59 PM
vtekthis's Avatar
Default Re: act clutch (drchulo)
...yeah and from others
Old May 23, 2006 | 01:10 PM
miller's Avatar
im gonna give the tilton another shot in my car, one more chance and if it ***** me again im going elsewhere.
darren, thanks for the clutch this weekend. i will have her back in your hands some time within the next week or so.
Old May 23, 2006 | 01:33 PM
vtekthis's Avatar
Default Re: act clutch (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">im gonna give the tilton another shot in my car, one more chance and if it ***** me again im going elsewhere.
darren, thanks for the clutch this weekend. i will have her back in your hands some time within the next week or so.</TD></TR></TABLE>
mee too, i gonna keep it for another tim around, just seems it give me so many issues, but grabs dammm good
JDM R Cooker
Apr 12, 2008 12:27 PM
goldhatch94
Jun 9, 2007 07:22 PM
bb_one
Aug 13, 2006 02:43 PM
92DAturboteg
Aug 8, 2006 07:10 AM
mike93boost
May 25, 2006 10:41 PM
