Accusump
Old Jan 24, 2005 | 04:01 PM
RacerStev's Avatar
Default Accusump
Just wondering what size Accusump you guys are using. Just need enough oil to prelube and in case the oil pump breaks.
Looks like there are 1-2 and 3 quart sizes, there's also a "high pressure" unit.
The cheapie 1 quart doesn't use a piston between the oil and the air, is this good
enough??
Thanks! Steve
Old Jan 24, 2005 | 09:11 PM
93LSivic's Avatar
Default Re: Accusump (RacerStev)
I too have looked into the Accusump system. Why do you plan on using it? From G forces off the tree, or cause its a race car that is not often started daily? The latter is why I would use it as I dont think the sump problem off the line is an issue.
*Edit....damn beers. N/M just re-read you post. From what I've researched you probably wont need anymore than the 2 qt. setup.
Old Jan 25, 2005 | 01:17 PM
RacerStev's Avatar
Default Re: Accusump (93LSivic)
The oil pump is the big reason, cost me a turbo and a bottom end last year out
of no were.
The plan is a pressure swith to turn the engine off, and one way valve so the
accusump pressure won't go back to the broken oil pump and switch.
I just want to learn this lesson once!
So ya think 2 quarts is large enough??
Old Jan 25, 2005 | 02:34 PM
autoraceparts.com's Avatar
The small one I have used on road race cars for cornering. For what you are doing I would go with the large one, if the pump breaks you can go a further distance with the more oil.
Old Jan 25, 2005 | 04:25 PM
Sgt Craig's Avatar
Your not the only one that had one fail. Let me know how it works out Steve.
Old Jan 25, 2005 | 05:17 PM
Scott Mohler's Avatar
Steve
Did you have the stock crank balanced in that motor?
Old Jan 25, 2005 | 07:25 PM
RacerStev's Avatar
Default Re: Accusump (Scott Mohler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott Mohler &raquo;</TD></TR><TR><TD CLASS="quote">
Steve
Did you have the stock crank balanced in that motor?</TD></TR></TABLE>
Well, I think so. I sent the rotateing ***. to a shop that I trusted. Turned
out there balancer was broken and it got subed to someone I would have
avoided at all cost's. Of course I found this out way after the engine was back
in the car.
I just wish Jim Justice was a couple hundred miles closer to me!
Steve
eg-gsr423
Oct 27, 2009 08:57 AM
DJ-Cool
11
Jun 27, 2007 11:02 AM
jarven093
11
Apr 30, 2007 07:00 PM
B16A1-EF9
Dec 12, 2002 06:42 AM
untuned
Nov 1, 2002 07:43 AM
