60ft Times
Old May 28, 2006 | 06:34 AM
BoOsTiN Dc2's Avatar
Default 60ft Times
What kind of 60ft times are u high hp turbo guys cutting without LSD? I'm currently running a gsr tranny without lsd on 25x8.7x13 slicks 6 1/2 - 7 psi tire pressure. I'm launching my car at 6k rpm and spinning in 1st gear hitting mid 1.8s for my 60 ft time. My setup is below
dtr traction bar
koni yellow with ground control 450lbs spring rate
gsr tranny
tilton twin disk 10lbs flywheel
6k launch w/2step
i'm getting stiffer drag suspensions already... and plan on getting quaife lsd in the future. Is there anything else i'm forgetting that will cut down my 60ft time?
Old May 28, 2006 | 02:25 PM
Humble Performance's Avatar
Default Re: 60ft Times (BoOsTiN Dc2)
I have LSD on my car but I would suggest going a little lower on your tire pressure , try 6.5 check to see how it likes it , then try 6. You should be able to cut 1.7's no problem , maybe even better. How much power are you making ? Depending on your hp your tire could be to big for your application at the same time affecting your 60ft times as well. What gear are you heating up your tires in ?
Old May 28, 2006 | 04:12 PM
Default Re: 60ft Times (8secEg)
im making 600hp... heating up the tires in 2nd gear.
Old May 28, 2006 | 04:46 PM
nonvtecallmotor's Avatar
I dont make 600whp but My 60's are low to mid 1.6's on a 24.0x9.2x15 slick with a open diff. in a 2400 pound street car.
My best 60' was a 1.61
My best pass was a 11.08 @ 126 with a 1.62 60' on about 375whp.
I preload the clutch and have my launch boost set at 7psi with the 2 step at 6300rpm.
Oh and 3rd gear burn outs for the win
Old May 28, 2006 | 04:55 PM
Default Re: 60ft Times (nonvtecallmotor)
what kind of suspension setup are you guys running?
Old May 28, 2006 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOsTiN Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of suspension setup are you guys running?</TD></TR></TABLE>I have Mugen low boy set up
Old May 29, 2006 | 12:35 AM
jep's Avatar
jep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor &raquo;</TD></TR><TR><TD CLASS="quote">I dont make 600whp but My 60's are low to mid 1.6's on a 24.0x9.2x15 slick with a open diff. in a 2400 pound street car.
Oh and 3rd gear burn outs for the win</TD></TR></TABLE>
Does preloading your clutch at 6300rpms wear it out prematurely?
Old May 29, 2006 | 01:47 AM
CETVTOGEM's Avatar
i have 25" slicks, and i cut 1.7-1.8 at my shitty track, but i ran consitant low 1.6's and one 1.58 in vegas.
new slicks, will cut your 60' down about 1tenth.
i have omni power drag coil overs,L-con traction bar, qauife lsd..
Old May 29, 2006 | 04:38 AM
Default Re: 60ft Times (CETVTOGEM)
do you guys think i have to launch higher? i'm spinning in 1st gear though launching at 6k rpm. i don't preload the clutch because my clutch activated msd wouldn't work together... i just drop the clutch
Old May 29, 2006 | 04:41 AM
I would say go lower on tire pressure and see how it reacts. Are you launching with a 2 step or just launching it by foot ?
Old May 29, 2006 | 05:12 AM
msd 2 step... is 6k rpm good enough for the launch or should i launch lower or higher? i know 6k rpm isn't that much on slicks compared to what other people are launching at
Old May 29, 2006 | 08:24 AM
PRELOAD IS A MUST
Old May 29, 2006 | 02:36 PM
CETVTOGEM's Avatar
drop air pressure around 5.5psi and try launching at 7500-8000
Old May 29, 2006 | 03:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOsTiN Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">msd 2 step... is 6k rpm good enough for the launch or should i launch lower or higher? i know 6k rpm isn't that much on slicks compared to what other people are launching at</TD></TR></TABLE>
Try bumping it up to 6,600 rpm and drop the tire pressure and see how it likes that. Compare to your other slips and go from there.
Old May 30, 2006 | 04:29 AM
i'll give it a shot and i'll find out on wednesday
Old Jun 3, 2006 | 08:31 PM
T4eg's Avatar
also as stated above try 3rd gear burnout...night and day diff over 2nd gear. i ran 7psi and 3rd gear burn outs on 25 8.7 mh and was consist low 1.6's.
chris
Old Jun 3, 2006 | 09:12 PM
Default Re: 60ft Times (T4eg)
best i did on the 60ft time was 1.717 once... but other then that it was better then last time... in the high 1.7 and low 1.8.
Old Jun 4, 2006 | 06:08 PM
Dc4turbo408's Avatar
I'll be out there Wednesday, tuned by Mased the same day u did homie.. The black integra with low whp.. lol
lamonte619
Sep 6, 2010 09:40 AM
dookieK9
Nov 5, 2007 10:34 AM
Itr001
Jan 5, 2006 08:59 PM
quikrpm'z
Sep 9, 2001 12:52 PM
