16 volts conversion
Old Nov 16, 2016 | 11:02 AM
CJPTuning's Avatar
Default 16 volts conversion
Hello guys, I am in the process of switching the drag car to 16Volts and would like to know
what batteries are you using size and brands and alternators, and fitment on Honda K series in particular.
Do you know of a company that sells alternators + brackets for this engine?
Thanks alot
Old Nov 16, 2016 | 12:40 PM
93ericSi's Avatar
Default Re: 16 volts conversion
A lot of people I've seen use XS power
and never seen someone run an alternator on 16V setup, that's why the switch to 16V is usually made = no more alt
Old Nov 17, 2016 | 01:25 PM
SPOOLINmatt's Avatar
no alternator just charger. You can get do the 16v alternator but what is the point?
I use the XS D Series 16volt. Keep it charged and keep the charger on it as much as you can through the cold months and during long breaks.
Old Nov 17, 2016 | 02:12 PM
redboost10's Avatar
Been using the same Rock Racing 16V battery for 3 seasons now. I feel batteries in general are hit/miss.. The only one I have ever had problems with not keeping a charge when purchased new was TurboStart.
Old Nov 21, 2016 | 11:30 AM
CJPTuning's Avatar
Thanks guys for your help. So it looks like XS power is the prefered one and without alternator.
I am calculating that i need approx 120amps during the run and the XS D1600 is rated at 50ah.
What voltage do you end up with after the race?
Old Nov 21, 2016 | 12:31 PM
16.9 unloaded before a race and 16.5 after one race unloaded. I can get 2 passes in between charges easily before i notice a change in the starter and fuel pump. I usually charge every pass though.
Old Nov 21, 2016 | 01:38 PM
doood's Avatar
been there done that
Is any additional wiring needed when converting to a 16v system or does it wire up like a normal battery?
Old Nov 22, 2016 | 07:29 AM
Nothing different other than you gotta usually cut the batt terminal connection off and swap it to whatever fits the new batt.
Old Nov 26, 2016 | 10:03 AM
CJPTuning's Avatar
Thanks alot guys for the info, I have ordered the XS power 16v battery D1600 model, looks like alot of people found it great
Honda_Tech01
Aug 2, 2008 11:06 AM
AllMotorRandy
Sep 3, 2005 01:35 PM
rice a roni
Mar 28, 2005 05:03 AM
JBk24crx
10
Nov 15, 2003 11:14 PM
