15 second auto integra
Old Oct 26, 2015 | 11:55 PM
96ekb20's Avatar
Default 15 second auto integra
96 ls integra nothing removed full daily driver b20 wit ycp pistons crowler 403 cams the rest is stock in the motor. 3" short ram blox v stack no filter dc sport header 2" exhaust straight piped to a fart can. stock injectors stock fuel pump stock regulator. maxed out the injectors and fuel cutting in 3rd gear ran a 15.3 flat hear in redding California. Will be putting 285 cc injectors in a 255 e85 fuel pump adjustable regulator and a fuel psi gauge. will be turning the pressure up to 50psi rmf 4-2-1 try y header with adjustable test pipe and retunning hoping to break high to mid 14s mite pull bumper supports to help weight.
Old Oct 27, 2015 | 12:55 AM
SonicRacing1's Avatar
Default Re: 15 second auto integra
Old Oct 27, 2015 | 10:50 PM
96ekb20's Avatar
does pull bumper supports or putting holes in the rear bumper realy help?
Old Oct 27, 2015 | 10:58 PM
sr20paisa's Avatar
do a diy bumper diffuser and strip out the sound deadning, also if you have a velocity stack, get a tube remove the headlights for better airflow and tape up the headlights for better aero(ghetto aero)
Old Oct 27, 2015 | 11:00 PM
sr20paisa's Avatar
so yeah the "holes" you speak of will reduce drag and will help
Old Oct 27, 2015 | 11:01 PM
96ekb20's Avatar
Old Oct 27, 2015 | 11:02 PM
sr20paisa's Avatar
an example of the taped up headlight, yes folding the mirrors will help too
Old Oct 27, 2015 | 11:04 PM
96ekb20's Avatar
sorry for the double post. computer froze. ya havent done the headlight yet as to we are already maxin out the fuel. isnt it easyer just to pull the rear bumper at the track then put wholes in it though? how much weight is to be lost by pulling sound deading out remember this is a daily not all out race car
sr20paisa's Avatar
taking off the bumper supports removes weight
putting holes in the bumper help reduce drag, if not go ahead and removing the whole rear bumper that will help too
Old Oct 27, 2015 | 11:05 PM
96ekb20's Avatar
how much did the tape and miors help time wise ? have u pulled the front bumper support to cut weight if so how much weight did u lose with front and rear gone?
Old Oct 27, 2015 | 11:06 PM
sr20paisa's Avatar
yeah i have tried the tape technique on freinds integra he said he felt a slight difference but he's deep into the 12's
the sound deadning should weigh more than 25lbs but less tan 45lbs more or less
btw is the p/s and ac still on it?
Old Oct 27, 2015 | 11:08 PM
96ekb20's Avatar
the owner also has a rear visor on do you think that may be causeing a air sucktion as the air rolls over the car? ya i think he rather pull the bumper then cut whole in the bumper. ya this car with me driving weights 3000lbs with the owner 3190. so weight reduction to a point is needing done.
Old Oct 27, 2015 | 11:10 PM
96ekb20's Avatar
yes there still on its a daily driven car. its driven 102 miles to the track beat down the 1/4 mile 10-12 times and driven 102 miles back. we did pull the power steering belt for two reason one hp gain and speed stability
96ekb20's Avatar
where is all the sound damping at ?
Old Oct 27, 2015 | 11:12 PM
sr20paisa's Avatar
my gess on the bumper supports is 2-30lbs but i recommend they should e on while daily driving
Old Oct 27, 2015 | 11:15 PM
sr20paisa's Avatar
this is sound deadning, the black stuff it weights alot
use dry ice or a heat gun and a scraper to remove it
look around you trunk, you wont miss it
96ekb20's Avatar
well a type r bumper support isnt even half of what the ls or gsr or rs is. was thinking of leaving he rear off and moding the front to be like a type r.
Old Oct 27, 2015 | 11:16 PM
96ekb20's Avatar
ok ill talk to the owner. ya this thing had the rear seat front seat carpet door panels everything in it lol just like a grocery getter would
Old Oct 27, 2015 | 11:17 PM
sr20paisa's Avatar
i think it's just for show, i would take it off it looks better and less drag
Old Oct 27, 2015 | 11:19 PM
96ekb20's Avatar
thanks for your help. wish 96+ integras came with manuel window doors to light the car up. but still beable to move the window. hope this car will move to high 14s with the things where adding then next will be better intake and tb then the bottle. hoping for low 14 or 14.0 all motor when done then 13.0 on 100 shot on 91 mix with 114
sr20paisa's Avatar
sounds good just make sure you have some sort of reinforcement, for the rear just remove the bumper with the support and when leaving the track re-install it and your good to go, it's really dangerous daily driving with out one
Old Oct 27, 2015 | 11:20 PM
sr20paisa's Avatar
sounds really interesting, hope this helps
Old Oct 27, 2015 | 11:22 PM
96ekb20's Avatar
do you think since it has a full radiator that if we took a spare front bumper and are roll of hard sheet plastic and blocked off the lower bumper opening for track use only that it would help and just run the heater all the time befor a run and turn right now after u pass the 1/4 mark? and leave on til u shut car off
Old Oct 27, 2015 | 11:25 PM
96ekb20's Avatar
thanks going back to the track on the 7th to see what the few upgrades help car should of did a 14.9 if it wasnt for the fuel cut. so a retune and few more upgrades and some aero wrok and taking the 205-5016 off the rear for some steelies should give a nice increase
Old Oct 27, 2015 | 11:27 PM
sr20paisa's Avatar
here's a few weight reduction threads i thought would be helpful
212lb weight reduction & list - Team Integra Forums - Team Integra
Weight Loss Guide 94 - 2001 Integra Coupe - Honda Forum : Honda and Acura Car Forums
