12's at least?
Old Apr 9, 2003 | 09:59 PM
CM-R's Avatar
Default 12's at least?
i have the exact same problem as DOHCarp i cant hit 12's...setup is stock GSR motor with 273.5 whp and 204.2 tq. with M/T 24.5x8x13 on 13 inch lenso's 12psi tire pressure
I dont think i burned out long enough (2-4 secs)
My 1/4 mile slip says: (Two step was NOT used)
reac= .539
I1=2.229
I2=5.852
I3=8.847
Mph(I3)=84.170
I4=11.359
E.T.=13.495
MPH=106.738
My other 60 ft' was 2.019 with two step set to 5,200, but misshifted 2nd and 3rd gear and got a 14 sec pass. I think this should have been a 12 but i never tried it with two again since i got scared of hitting 14's again for some reason...any info would help
Old Apr 9, 2003 | 10:28 PM
kill bill's Avatar
Default Re: 12's at least? (CM-R)
you dont know how to drive..on street tires my 60 ft is a 10th better than yours on slicks...
Old Apr 10, 2003 | 05:25 AM
1 2 NV's Avatar
hell i hit 12s with 103 trap speed. hell yeah its there, can u do it??? i dunno.
Old Apr 10, 2003 | 06:21 AM
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CM-R &raquo;</TD></TR><TR><TD CLASS="quote">i have the exact same problem as DOHCarp i cant hit 12's...setup is stock GSR motor with 273.5 whp and 204.2 tq. with M/T 24.5x8x13 on 13 inch lenso's 12psi tire pressure
reac= .539
I1=2.229
I2=5.852
I3=8.847
Mph(I3)=84.170
I4=11.359
E.T.=13.495
MPH=106.738
1. Lower your tire pressure.
2. Doing a burnout too long can hurt traction.
3. 2 Step should be set way higher. Try a 7500rpm.
4. What springs and shocks are you running????
Old Apr 10, 2003 | 06:31 AM
Gmedalion's Avatar
Default Re: 12's at least? (FUCATYPR)
try launching at 6500-7000 with the slicks on, u should be getting 1.8 60 foots. 2.0-2.2 are terrible with slicks.
Old Apr 10, 2003 | 10:04 AM
turbodsmpower's Avatar
Default Re: 12's at least? (Gmedalion)
Yah it takes practice defently need practice on drag radials i can pull consistent 2.0 on slicks and that size you shoud be able to pull 1.8's My buddy w/ 20x8x14 pulled numerous 1.9's and thats what it took for him to hit 12's. Just keep practicing. Good luck
Old Apr 10, 2003 | 11:08 AM
CM-R's Avatar
Default Re: 12's at least? (turbodsmpower)
I'll practice a lot more when i get the chance thanks for the info....My suspension setup is GC coilovers and stock shocks.. ... should i just dump the clutch or feather it then dump it real quick?
Old Apr 10, 2003 | 03:22 PM
DOHCarp's Avatar
Don't worry CM-R we'll hit 12's soon!!!
Old Apr 10, 2003 | 06:31 PM
ONE SLOW EG's Avatar
Default Re: 12's at least? (DOHCarp)
u got the mph, work on launch and 60's definately, im runnin consitant 1.9's with 20x8x14 m/t but u can definately do it with practice. check my sig for the rest
Old Apr 11, 2003 | 12:40 AM
Hard2Find's Avatar
Default Re: 12's at least? (b-18 bomber)
i hit 12.9 @ 108......with 1.9 60'
when i had 2.0 60' i hit 13.1
same setup at 9lbs of boost on stock gsr motor with fmax + thick headgasket and same slicks are yours
Old Apr 11, 2003 | 03:09 AM
the-anti-crack's Avatar
stock shocks
Old Apr 12, 2003 | 05:24 AM
SpeedVelocity.org's Avatar
Default Re: 12's at least? (i need space)
hahahahaha...............LOL
Old Apr 12, 2003 | 06:43 AM
ATYPR's Avatar
Default Re: 12's at least? (SpeedVelocity.org)
The last drag car we set up pulled 1.6 60ft all day long. You NEED adjustable shocks and coilovers.
Old Apr 13, 2003 | 12:03 PM
CM-R's Avatar
Yea Yea i know i suck...lol....don't have to rub it in
I'll look into getting shocks soon illuminas maybe....i am sick of the GC plus stock blown shock combo
ringgold
Apr 22, 2007 07:15 PM
grnhatch94
Jan 30, 2006 07:40 PM
B_1_8_hatch
Nov 9, 2003 07:06 PM
speedyonez
21
Aug 27, 2003 11:15 AM
99lspwr
Jun 16, 2003 10:26 AM
