is 11s feasable?
Old Dec 13, 2004 | 12:22 PM
Jockobo's Avatar
Default is 11s feasable?
juss ran a 7.88@91 in the 1/8th at a shitty track with no vht on 24.5 inch slicks...does 11s seem possible with this set up? 60 fts were only 1.93 cause i suck at driving...what does 91 mph usually equate to in the quarter...i would like to run the 1/4 mile soon but tracks are down for the winter...basic set up volvo t3 15-20 psi afc eclipse injectors combo...ls with thicker head gasket arp head studs compression mid 8s...2200+ pounds...the whole set up is listed here...56k dont click...
https://honda-tech.com/zerothread?id=1074877
Modified by Jockobo at 7:39 PM 12/15/2004
Old Dec 13, 2004 | 01:11 PM
turboEGhatch's Avatar
Default Re: is 11s feasable? (Jockobo)
It'll be pretty close, we had a friends car at the strip last week of summer, it went 7.7 @ 94 with a 1.8 sixty in the 1/8 mile, and went 11.9 @ 115 I believe in the 1/4. I think a 12.0 or a 12.1 is pretty doable, but you might need a bit more to squeek out an 11.
Old Dec 13, 2004 | 02:00 PM
hondaguyef's Avatar
Default Re: is 11s feasable? (turboEGsedan)
You should be pretty close. I ran 7.96 in the 1/8 and 12.42 in the 1/4 on that same pass. How do you like the 24.5's? I am getting a set and I think they might be too big.
Phil
Old Dec 13, 2004 | 02:15 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
on a good day with some good 60ft time you can go into the 11's. i ran a 12.076 in my turbo ls- EF on 13lbs. 2360 with driver. 22/8/13 slick =bad 60ft time tho
60---1830
330--5.092
1/8--7.783 @90.54
1000-10.117
1/4--12.076 @115.50
Old Dec 13, 2004 | 04:24 PM
Jockobo's Avatar
Default Re: is 11s feasable? (TURBO BLUE HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">You should be pretty close. I ran 7.96 in the 1/8 and 12.42 in the 1/4 on that same pass. How do you like the 24.5's? I am getting a set and I think they might be too big.
Phil</TD></TR></TABLE>
i love the 24.5's...feels really smooth off the line compared to the 22x8x15 that i usually run...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO BLUE HATCH &raquo;</TD></TR><TR><TD CLASS="quote">on a good day with some good 60ft time you can go into the 11's. i ran a 12.076 in my turbo ls- EF on 13lbs. 2360 with driver. 22/8/13 slick =bad 60ft time tho
60---1830
330--5.092
1/8--7.783 @90.54
1000-10.117
1/4--12.076 @115.50</TD></TR></TABLE>
that's encouraging
Old Dec 13, 2004 | 05:16 PM
nsxmatt's Avatar
It took me a 7.6 to hit 11.9's. Looks like if you get a better 60ft you could do it, just depends how your cars pulls up top which you won't know till you take it out on the 1/4.
Old Dec 13, 2004 | 05:48 PM
hondaguyef's Avatar
Default Re: is 11s feasable? (nsxmatt)
Don't listen to NSXmatt! His car is just F&%king amazing!
Phil
Old Dec 13, 2004 | 05:59 PM
Jokerluv's Avatar
good times man
Old Dec 14, 2004 | 12:00 AM
Jdm_Rice_Monster's Avatar
Default Re: (Jokerluv)
I think its possibly...I ran a 12.1 and my 1/8 time was a 7.80 @ 91mph...on a near perfect run it can be done....might have to change a few variables but it could happen.
Kev-turboEJ1
Nov 30, 2006 06:10 PM
orion840
Oct 12, 2006 06:08 PM
Modify
Oct 12, 2004 07:06 PM
cornhusker
Apr 7, 2004 07:29 PM
brent_G
11
Aug 28, 2003 02:46 PM
