11 sec SRT4
we have a local srt4 with stock turbo and 100 shot going 7.50s@96mph in the 1/8. he also went 12.1@117 w/ a 30mph headwind a few weeks back. needless to say, his car would be deep in the 11s if it werent for the wind that day.
Once we swap out the stock clutch, intercooler, and throttle body (47mm to a 60mm) We are going to bump the boost from 22psi to 28psi. We are gunning for high 10s with this car. It has a 57 trim innovative turbo.
Anthony obviously you were driving right ?? Thats the customers care you were running at Survival Series right ??
Where did you pick up the .3 from what you ran in your car... but with less mph ?? I know you went 12.3X @ 113.XX I know you went 1.8X on that run...
Congrats...
Congrats...
Hey Tim
This was Mike (Tiny)'s car. He was actually driving the car. He is picking up the driving very quick. This was his 3rd time at the track. He cut a pretty good light too
We dumped the drag radials and put on some M&H slicks. That stock intercooler is a brick wall after so much CFM. We can add more boost with minimal results. The 12.3 was in our stock turbo car that weighed in at 2900lbs. Tiny's car weighted in @ 3k lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blitzkrieg »</TD></TR><TR><TD CLASS="quote">Hey Tim
We dumped the drag radials and put on some M&H slicks. That stock intercooler is a brick wall after so much CFM. We can add more boost with minimal results. The 12.3 was in our stock turbo car that weighed in at 2900lbs. Tiny's car weighted in @ 3k lbs.</TD></TR></TABLE>
Gotcha he was driving.. I know it was 2 different cars i'm not that dumb lol...
I was just using the times as comparison..
We dumped the drag radials and put on some M&H slicks. That stock intercooler is a brick wall after so much CFM. We can add more boost with minimal results. The 12.3 was in our stock turbo car that weighed in at 2900lbs. Tiny's car weighted in @ 3k lbs.</TD></TR></TABLE>Gotcha he was driving.. I know it was 2 different cars i'm not that dumb lol...
Psi Fi Motorsports Upper and Lower Dogbone Motor Mounts
Innovative T304E Turbocharger
Psi Fi Motorsports Custom 3" O2 housing
Psi Fi Motorsports Custom Turbo Manifold
Turbosmart External Wastegate
Return fuel system with rising rate regulator and in-tank pump
Psi Fi Motorsports Custom Charge Pipe
Turbosmart Blow Off Valve
Psi Fi Motorsports 3" Cold Air Intake
Exhaust Depot 3" Turbo back exhaust
Psi Fi Motorsports PowerPaq
Mopar Stage 1 ECU
Turbosmart EBOOST Electronic Boost controler
IPP Full 32 way adjustable coilovers
RC 650cc Injectors
Drive Shaft Shop stage 3 axles
15" 11lb race wheels w/ 24.5x8x15" MT slicks at 13psi
Mopar Stage 1 ECU
RC 650cc Injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blitzkrieg »</TD></TR><TR><TD CLASS="quote">Psi Fi Motorsports Upper and Lower Dogbone Motor Mounts
Mopar Stage 1 ECU
RC 650cc Injectors
damn
sounds like fun..
im not a fan of neons, but i respect the fast ones
Mopar Stage 1 ECU
RC 650cc Injectors
damn
sounds like fun..
Mopar Stage 1 ECU
RC 650cc Injectors
damn!!
stock block, head, intake manifold, cams?
did it spend any time on the dyno to get tuned?
edit:
i just watched the vid.
looks like the other neon didnt get as good as a launch but help up pretty good going into 2nd or 3rd gear until the end
yeah the other guy was fast too, but red neon still was fast
Mopar Stage 1 ECU
RC 650cc Injectors
damn!!
edit:
Syner-G-Racing LLC
Nov 29, 2004 01:06 AM
beastyboy81
33
Mar 8, 2002 07:14 AM
When are we gettin lined up again?
