1/4 mile time difference?
Old May 5, 2004 | 08:29 PM
TypeR_Turbo's Avatar
Default 1/4 mile time difference?
i have a 2000 ITR with just an Injen Cold Air intake. I ran a 15.0@95mph. But last year i had the cold air, cat-back apexi N1 and h&r race springs with koni shocks. That set up ran a 14.6 @ 94mph.
Now that the car is at stock height again, can i run any better than a 15.0. Need info. Must i need to lower the car again to get better times. and it's weird cause i'm running a better mph with out an exhaust.
Old May 5, 2004 | 08:33 PM
PNG's Avatar
PNG
Default Re: 1/4 mile time difference? (TypeR_Turbo)
Let's isolate the variables here.... air temp, track prep, launch rpm, etc. will all effect your elapsed times. I don't suppose you're keeping track of all your passes in a logbook, are you?
Old May 5, 2004 | 08:38 PM
Default Re: 1/4 mile time difference? (PNG)
most of my runs last year (14.6) were running 2.2 60ft's and running 94mph or less
and the runs this year were 2.4 and 2.6 60ft's
now both years i'm running the same tires at the same psi and launching exactly the same also. but i guess it all depends on how the track is prepped also.
is this a respectable time at 3000ft elevation? what would my times be at sea level?
Old May 5, 2004 | 08:47 PM
megotvtec's Avatar
if you run a 14.6 at 3000' you'll be right around 14.2 at sea level
2camvtec
Apr 28, 2004 09:47 AM
tegmech
Jul 17, 2003 09:39 PM
snake01
Jul 5, 2003 02:31 PM
integranator
Nov 21, 2002 10:06 AM
shermanyang
Jun 12, 2002 05:18 PM
