1/4 mile launch
Old Jan 8, 2003 | 09:55 AM
luiggie's Avatar
Default 1/4 mile launch
I need some help to launch my teg, what is the max rev to launch?
My setup is very quiet(Integra 2000 GSR):
DC 4-1, Short air filter.
Thanks
Old Jan 12, 2003 | 03:22 PM
D-Man's Avatar
Default Re: 1/4 mile launch (luiggie)
if its on street tires..around 3000rpm
if its on slicks..around 4000rpm
Old Jan 12, 2003 | 05:08 PM
boosted3g's Avatar
Default Re: 1/4 mile launch (D-Man)
you can get by with more revs than that with slicks. I hold it at around 7200 with a 2 step
Old Jan 12, 2003 | 06:56 PM
Bs's Avatar
Bs
Default Re: 1/4 mile launch (boosted3g)
6.5-7k launch with slicks.
Old Jan 12, 2003 | 08:37 PM
allmotor92civic's Avatar
Default Re: 1/4 mile launch (B_s)
4k on slicks????????try 7k and up. launchin at 4k or so u WILL break more axles than launching higher
Old Jan 12, 2003 | 10:38 PM
ISELLRIGHTHANDDRIV
Guest
Posts: n/a
Default Re: 1/4 mile launch (allmotor92civic)
i would launch at 3000 on street tires and 7500 on slicks, but you have to feather the clutch out or else you'll have sick wheel hop.
Old Jan 12, 2003 | 11:44 PM
JDMb18civic's Avatar
Default Re: 1/4 mile launch (ISELLRIGHTHANDDRIVES)
7k
Old Jan 13, 2003 | 01:16 AM
redteg1's Avatar
3000rpm on street tires? nooo no no no. i have a stock gsr cept for aem cai and i launch at 4500 rpm. they spin yes at first only a bit but after it grabs ur right up in the rpms right away. still manages a 14.8-14.9 e.t. and 2.3 60' launching at 3000 would cause the revs to drop out of the power range after grabbing. with my experience anything under 4000 rpm tends to bog. but thats just me.
Old Jan 13, 2003 | 03:11 PM
luiggie's Avatar
Default Re: 1/4 mile launch (redteg1)
Thanks!
I will try 3,500 because 4,000 begin to spin out of control.
Thanks!
PS
Street tires and bad weather(Puerto Rico) warm.
Old Jan 13, 2003 | 06:26 PM
bretx0r's Avatar
take note that launching on slicks at 7000+ rpm will aid you in finding weak links in your drivetrain system quite effectively, if you get what i am saying.
Old Jan 15, 2003 | 02:15 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: 1/4 mile launch (bretx0r)
which is why I run 20x8x14 slicks and a "weak" used Centerforce DF clutch setup.
I've launched at 7800 rpm many times, just make sure helmet is against head rest before dumping the clutch.
Old Jan 17, 2003 | 03:56 AM
luiggie's Avatar
Default Re: 1/4 mile launch (Mista Bone)
tttt
Another question.
I have a friend that use the e-brake for launch, rev the car til 5k pull the clutch a little and when the ligth turn green bummmm!
Advantage , Disadvantage??
tapboyzlilj
Jul 3, 2007 12:19 PM
Soda Popinski
Nov 21, 2005 07:24 AM
Dc4turbo408
Dec 17, 2004 04:46 PM
ALLMOTOR18
Jul 22, 2003 10:38 PM
Kermit EK
Aug 22, 2002 06:35 AM
