Detailing Auto Detailing and Concours
How To Remove Overspray from Glass
Old Oct 6, 2014 | 06:15 PM
TouringAccord's Avatar
H-T Order of Merit
Default How To Remove Overspray from Glass
Just thought I'd share my experience....
Long story short, after my car came out of a body shop recently I noticed it had a clear overspray all over it with exception to the panel that had been repaired.
Clay bar with detailing spray took the overspray off the paint as expected, but when it came to the windows the clay bar/detail spray combo wouldn't cut it. After doing some searching I came across a posting on eHow that worked nicely.
Things needed...
clay bar
soft towels
bowl
spray bottle
white vinegar
liquid soap
water
In a bowl, mix 1 cup of White Vinegar with 2 cups cold water. In a spray bottle, mix 2oz of soap with 24oz warm water. Using a soft towel, dip it into the water/vinegar mix, ring out the excess and wiper the overspray covered glass. Then spray the water/soap mix onto the window and rub the clay bar over it. Be sure to use enough water/soap to keep it lubricated as to not scratch the glass. After rubbing the clay bar over the glass, wipe off the water/soap/vinegar residue with a soft dry towel.
This worked really well for me and I thought I'd share in case anyone else has a similar problem.
Old Oct 24, 2014 | 12:23 AM
EsotericImage's Avatar
Retired Moderator
Default Re: How To Remove Overspray from Glass
Not to jack your thread.. Fine steel wool does the trick w/o any problems.
Old Oct 24, 2014 | 04:15 PM
98civdx's Avatar
Master Detailer
0000 steel wool, or Razor blade and lube.
But for me it's more time based. I don't have the time for all those steps. lol
Old Oct 24, 2014 | 07:37 PM
Retired Moderator
Steel wool is also great for chrome. Then I come back with a quick polish and theyve had the crud removed.
Bumpers, Wheels, exhaust pipes/tips..
Old Dec 13, 2022 | 10:38 PM
Marsha Harrison's Avatar
Hair spray is another viable option for dealing with paint overspray on glass. You can count on its alcohol content to break down the paint particles.
EK-MAX92
Detailing
11
Oct 13, 2012 09:46 PM
vegas
Detailing
Mar 18, 2010 09:03 PM
ferio252
Paint and Body
Feb 2, 2008 06:31 PM
I Want An Si
Jul 22, 2003 08:36 AM
Mike B
Apr 17, 2002 10:26 AM
