Sandwich Adapter
Old Jul 22, 2005 | 09:39 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Sandwich Adapter
NO NEED TO CUT WELD OIL PAN!!!!!
With this plate you can save yourself a lot of trouble with your DIY turbo setup. Install between the oil pan and filter and you can run your feed and return lines with no cutting or welding.
$50 SHIPPED Paypal Only
Old Jul 26, 2005 | 12:52 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Sandwich Adapter (Vt4cPwn35)
up
Old Jul 27, 2005 | 07:46 AM
213374U's Avatar
0x5359-0055
Community Builder
THIS HAS NEVER BEEN USED.
I'm not using this for my setup because I already have all the lines I need. If I were to use this I would need a longer feed/return line.
Old Jul 27, 2005 | 08:03 AM
GeeGee's Avatar
just so you know, the you can't run the return line up there.
Old Jul 27, 2005 | 12:56 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Sandwich Adapter (Krabbypro)
Why is this?? It's made as a feed and return line for an oil cooler. Why wouldn't it work for a turbo?? It's the same concept.
Back up your statement if your gonna post.
Old Jul 27, 2005 | 03:44 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">Why is this?? It's made as a feed and return line for an oil cooler. Why wouldn't it work for a turbo?? It's the same concept.
Back up your statement if your gonna post. </TD></TR></TABLE>
well for one your oil return is supposed to be as straight as possible pointing as down as possible. you would have to route your return around or under the oil pan and UP to the oil filter location......NOT the same principle
Old Jul 28, 2005 | 07:08 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Sandwich Adapter (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">
well for one your oil return is supposed to be as straight as possible pointing as down as possible. you would have to route your return around or under the oil pan and UP to the oil filter location......NOT the same principle </TD></TR></TABLE>
Thank you, an explanation is all I wanted.
gabe768
May 22, 2010 01:18 PM
Flexin5
Nov 7, 2006 11:41 AM
alfee
Jun 28, 2004 04:10 PM
rhettster
Jul 9, 2003 08:40 PM
TORQUE MONSTER
Sep 29, 2002 05:55 PM
