MSD-6BTM
Old Jun 21, 2004 | 12:12 PM
AnotherSi33's Avatar
Default MSD-6BTM
I was going through the closet and I forgot that I had a MSD-6BTM that I was going to use but didn't, it's brand new in the box, 425 shipped takes it, its for turbo or supercharged applications. Others sell it for at least $484 + shipping from what I've seen, it retails for $900+. Here are some details about it from MSD:
The 6 BTM is ideal for engines with a turbo or supercharger. Not only will the engine benefit from MSD’s full power CD sparks, but there is also an adjustable boost/timing retard circuit to prevent detonation.
When your supercharger (turbo or blower) forces the air/fuel ratio into the engine, the cylinder pressure inside the combustion chamber increases. The result is a great amount of power but this can also lead to detonation which can result in severe engine damage. The 6 BTM lets you dial away detonation by retarding the timing in relation to the boost pressure. By electronically controlling the ignition timing your engine can run on the threshold of detonation to obtain maximum power and efficiency.
The BTM features a dash mounted control **** that lets you adjust the amount of timing retard. It can be adjusted from 0° per pound of boost to 3° per pound. The boost pressure is monitored by a sensor built into the MSD.
The 6 BTM also shares the Soft Touch Rev Control of the 6AL Ignition for overrev protection. The BTM is supplied with rubber shock mounts and rpm modules for 3,000, 6,000, 7,000 and 8,000 rpm.
MSD 6 BTM Ignition Control
w/Boost Timing Master, 4, 6 (even-fire only)
and 8-Cylinder
PN 6462
NOTE: Not compatible with distributorless systems.
NOTE: With an MSD 6 Ignition, some factory and aftermarket tachometers and fuel injection systems may require an MSD Tach/EFI Adapter.
OPERATING SPECIFICATIONS
Operating Voltage: +10-18 VDC Negative Ground
Current Requirements: 5 Amps-5,000 RPM
10 Amps-10,000 RPM
RPM Range: 15,000 RPM with 14.4 Volts
Spark Duration: 20° Crankshaft Rotation
Energy Output Max: 105-115 mJ Per Spark
Weight and Size: 3 lbs, 8"Lx4"Wx2.25"H
Voltage Output Max: Primary: 460-480 Volts
Secondary: 45,000 Volts (Blaster Coil)
Old Jun 23, 2004 | 10:18 AM
Default Re: MSD-6BTM (AnotherSi33)
anybody wanna make a reasonable offer, it is still brand new
Old Aug 25, 2004 | 07:15 AM
$275 shipped, I checked to see how much this goes for, brand new in the box
Mase
Nov 16, 2011 04:19 PM
Charlie Moua
Jul 10, 2002 10:02 AM
Lei Siew Long
May 7, 2002 08:39 AM
