GSR turbo kit with Boost programmable ecu
Like the title says. F-Max complete turbo kit for 94-01 GSR: manifold, pipes, filter, wastegate, HKS race blowoff, Link programmable ecu. Turbo is great shape. No oil leaks and no shaft play. Will work with other cars with B-series motors if you modify it. Better than Drag since you don't need to grind down your block to get the turbo to fit.
Located in OC, but can bring up to the bay and asking $1500 for all of it. Feel free to contact me if you have any questions.
what size/kind of turbo?
what does the "link programmable ecu control........ Timing? Air Fuel? Under Load? or WOT? What is it called? How many miles on the kit?
t3/t4 turbonetics turbo. minimal shaft play with no axial movement. link ecu is very popular with the boosted miata circles. it controls everything, fuel, timing, rpm, etc all while using the factory sensors. can run up to 1 bar with stock map. have 2 bar map included in kit if you want to boost more. here is a link to the ecu.
http://www.link-electro.co.nz/
f-max turbo that comes with the kit is a t3t4b and i taught that the fmu box controlled the 2 450cc injectors in the charge pipe
What else would I need to bolt this up and have it run perfect and safe on my GSR? Does it let you keep AC? Does it come w/ intercooler and pipping?
TwoKSiR
Engine Management and Tuning
Jun 14, 2008 07:07 PM
psidriven
Jul 20, 2004 06:15 PM
