Fully Built B18C1 with complete turbo Kit !!!!!
This a FULLY Built B18C1: 8000 miles since LHT Built $7500
If your looking for a Fully built motor, turbo and Hondata THIS IS A DEAL !
Golden Eagle sleeved B18C1 block 84mm
CP Pistons and rings
Crower billet rods (Not Econo)
OEM Bearings
OEM Water pump, T belt tensioner
OEM oil Pump
Balance OEM Crank
New OEM Distributer
Endyn ported ITR Head (New)
ARP Head studs
ITR cams (New)
Skunk 2 cam gears
Skunk 2 intake manifold
LHT 68mm throttle body
New valve cover
Motor is in perfect shape, no piston slap . oil buring or rattles etc
LHT400 turbo kit
Thermal coated Cast manifold
3" Stainless DP ,Re circ Dump tube
Precision 600hp intercooler
2.5" Aluminum piping and couplers
Stainless feed and drain line
Precision 880cc injectors
TIAL Waste gate
TIAL BOV
Hondata S100 and ECU Already tuned to 350whp at 12 psi.
The turbo is good for around 430whp
The motor is good for 600whp +++
$7500 NO Trades, No Haggling. Add this up and see how good this is .
All you need is your tranny and engine harness.
Everything else is included!
We'll even install it for you.
Here's what it looks like
http://www.tamparacing.com/forums/lh...-civic-ex.html
OEM Bearings
OEM oil Pump
Balance OEM Crank
New OEM Distributer
ARP Head studs
ITR cams (New)
Skunk 2 cam gears
New valve cover
LHT400 turbo kit
TIAL Waste gate
TIAL BOV
CRVRX
Aug 21, 2009 06:42 PM
