FS:: Tons of Modified parts!!!!!!!!!!!
Old Jul 8, 2010 | 08:19 AM
buck02's Avatar
Default FS:: Tons of Modified parts!!!!!!!!!!!
Need to sell this stuff out my garage.
2200lbs Injectors
MSD Fuel pump booster 150.00
10lb Nitrous Bottle Valves $20 each or 35 for both
Cage Gauge mounts $35 for both
Fass 220 GPH fuel pump brand new $500
Spearco Inline water pump Brand new $75
Speed Sensor B-series $40
Hasport t88 Mount Inserts $20 for all 3
Clutch Master Cylinder New $25
GSR Oil Pan Tap for turbo oil return With -10an hose and fittens $50
92-00 Civic Hubs with ARP extended wheels studs $35
96-00 Civic Sprint Drop springs $50
01-04 Civic Sprint Drop Springs $50
GSR Transmission Case $150
P28 Virgin Ecu $85
P72 OBD2 ECU $50
96-00 Civic SubMember with rack and pinion $50
Old Jul 8, 2010 | 09:03 AM
Luke G.'s Avatar
Default Re: FS:: Tons of Modified parts!!!!!!!!!!!
pm'd
Old Jul 8, 2010 | 11:59 AM
sh!ft's Avatar
Who the fack changed my title?!
those injectors, how much, and as in terms of comparison to cc, what are they?
Old Jul 8, 2010 | 12:20 PM
tunedX's Avatar
Are those rear wheel hubs??
Old Jul 9, 2010 | 07:01 PM
buck02's Avatar
there front hubs
Old Jul 9, 2010 | 07:06 PM
buck02's Avatar
the injector info
Tested flow rates:
210 lbs/hr at 43.5 PSI, 2200 cc/min at 3 BAR
225 lbs/hr at 50 PSI, 2375 cc/min at 3.5 BAR
240 lbs/hr at 58 PSI, 2550 cc/min at 4 BAR
258 lbs/hr at 65 PSI, 2700 cc/min at 4.5 BAR
273 lbs/hr at 72.5 PSI, 2865 cc/min at 5 BAR
286 lbs/hr at 80 PSI, 3010 cc/min at 5.5 BAR
300 lbs/hr at 88 PSI, 3155 cc/min at 6 BAR
320 lbs/hr at 101.5 PSI, 3350 cc/min at 7 BAR
how many injectors you want? i will price them by the single or the amount needed
Old Jul 11, 2010 | 12:01 AM
blowBY EG6's Avatar
pm sent!
Old Jul 12, 2010 | 08:33 AM
buck02's Avatar
pm replied
Old Jul 29, 2010 | 02:01 PM
buck02's Avatar
updated
Old Jul 29, 2010 | 03:20 PM
sh!ft's Avatar
Originally Posted by buck02
the injector info
Tested flow rates:
4 and will these fit hondas? that was never specified. i need something close to 1000cc or that can support over 600hp
Old Jul 30, 2010 | 12:18 PM
KdF's Avatar
KdF
I need that subframe And what are those mount inserts for?
Old Jul 31, 2010 | 02:24 AM
SlaminSohCivic's Avatar
Hey Man That MSD Eletric Fuel Pump Its External? And is it Smallers or Bigger then Walboro 255lbh Because i Need Sumthing to Push RC 750cc Injectors...And how Much for msd Fuel Pump/New Cluster Master Cylinder/Bronze Valve Guides Shipped to 15478
Old Jul 31, 2010 | 04:22 PM
buck02's Avatar
yes u will need the adapters or i can supply them. but yes they fit a honda.
Old Jul 31, 2010 | 04:23 PM
buck02's Avatar
to stiffeen the mount.
Old Jul 31, 2010 | 04:30 PM
buck02's Avatar
140+14.86 shipping
Old Aug 1, 2010 | 08:01 AM
g2crx's Avatar
can you pm me a price for the gauge mounts and shipped to 19703. thanx
Old Aug 9, 2010 | 10:24 PM
buck02's Avatar
gauge mounts are 7.34 shipped to you
Old Sep 7, 2010 | 07:52 AM
buck02's Avatar
updated
Old Sep 13, 2010 | 08:30 AM
buck02's Avatar
ttt
Old Sep 13, 2010 | 09:36 AM
RACEPAK's Avatar
Whats your best price on the water pump?
Old Sep 13, 2010 | 10:18 AM
buck02's Avatar
75 for the spearco wate pump.
Old Sep 15, 2010 | 10:43 AM
jaycorolla's Avatar
do you still have the p28 computer
Old Sep 15, 2010 | 11:03 AM
buck02's Avatar
yes i still have it.
Old Dec 30, 2010 | 09:50 PM
buck02's Avatar
up
Old Dec 31, 2010 | 01:36 AM
sh!ft's Avatar
80 over priced with shipping transmission casings bump. lulz.
