fs: supercharged engine setup
Old Jun 5, 2009 | 06:39 AM
jspeceg's Avatar
Default fs: supercharged engine setup
***NO TRADES***
*PICS TO COME*
AEBS 85.5mm bore B18C1 block $1000
SCAT 92mm stroke Crank $350
EAGLE B18B Rods
$200
Endyne 85.5mm (-8cc, 28.6512) pistons
$600
NEW ACL rod and main bearings $100
Apacolypse high flow oil pump $200
B18C1 Head - Built gsr head pp,milled, hot tanked, multi angle valve job, .5 over valves super tech valve springs, retainers valves, comp cams with adj. cam gears, milled .03
$600
B18C1 Jackson Racing SuperCharger
$1500
obd2-1 harness
chipped p28
jackson racing MAP controller
With the head and block combo, i expected around a 10.5:1 compression ratio with a .031 head gasket.
Will ship at buyers expense. paypal accepted (please add 3% to all transactions). prices pretty much firm.
Old Jun 5, 2009 | 10:04 AM
Nataku's Avatar
Default Re: fs: supercharged engine setup
has the head been used since the build? if so for how many miles roughly?
Old Jun 5, 2009 | 12:22 PM
jspeceg's Avatar
the motor has not been put together. but the head has roughly 2000 miles on it from previous owner.
Old Jun 5, 2009 | 02:25 PM
Nataku's Avatar
Did the previous owner provide receipts for the head? if so do you have those?
As well can you please provide pictures of the head?
And not to be stingy but do you have any vouches?
Thanks!
pb16b
Mar 15, 2010 03:37 AM
AllMotr
24
Jul 1, 2006 12:51 PM
PiMp0r
30
Mar 16, 2005 08:32 PM
