FS: Jackson Racing BTC (Boost Timing Controller)
***SOLD***
The JR Timing Controller is specifically designed for your
forced induction Acura. This unit has an extensive list of features,
which make this the best timing controller available.
• Base timing curve optimized specifically for the Acuras. Hundreds of hours on the dyno were needed to dissect and then re-map the perfect
timing curve. The timing curve is three-dimensional. It looks at RPM, Boost, and Timing. It only retards timing where necessary and timing is
advanced wherever possible.
• Only the highest quality industrial and automotive grade componentry
is used.
• All circuitry is encapsulated to provide superior protection against
moisture, vibration and shock.
• Circuitry has built in safeguards against incorrect installation,
improper jump starting and sudden electrical failure.
• Adjustable timing curve - allows up to 2 degrees of retard per pound
of boost. Adjustment is incredibly accurate using our in cockpit
adjuster. The **** has detents, which allow you to accurately make
changes or return to exactly where you started. Each click of the ****
is one tenth of a degree of retard per pound of boost.
Instructions Included
$150 shipped to lower 48 states
email me if interested: keebler65@mn.rr.com
Modified by keebler65 at 12:55 PM 4/4/2004
is used.
StreetRacin101
Mid-Atlantic (Sales)
Jul 17, 2008 11:09 AM
StreetRacin101
May 18, 2008 03:50 PM
