Fic 550CC Injectors
hey i have 4 used FIC (fuel injector clinic) 550cc injectors for sale worked great on my turbo d setup i upgraded to much larger injectors for an e85 setup these injectors worked flawlessly purchased these new from fic for 305 shipped selling for 195 shipped priority mail 2-3 days obo
Honda/Accura Injector Set: 4 x 550cc Peak and Hold/ Low Impedance Ball & Seat Injectors
http://www.fuelinjectorclinic.com/cg...key=IS115-0550
yes a resistor box is required you may be thinking of just getting saturated injectors
Peak and hold use more amps to operate but is a more accurate way of getting fuel into your engine because the ecu determines how long to open hold and close. Saturated injectors are high resistence injectors which uses less amps and sprays fuel into the engine because voltage tells it to.
so basically if your trying to make hp go with peak and hold injectors
if you have any questions 619-813-5149 name is james
gravelypuller
Jul 6, 2015 04:51 AM
