A few things FS...
I am trying to get rid of this stuff to make way for a new turbo set up....so here it goes:
brand new yokana front mount...measurements(i am farely sure) are 28x8x3 with 2.5 inch end tanks.....once again BRAND NEW..no bent fins....very shiny....asking $260 firm
Brand new in box greddy type s BOV...comes with everything (except flange of course).....once again on this one...BRAND NEW!!! asking $160 firm
used greddy B-Series turbo kit(NOT complete)....comes with almost everything....turbo (greddy 18g), turbo manifold (already tapped for an EGT), full downpipe (the other piece isn't pictured but it will come with it), lower intercooler pipes (the upper pipe that goes to the throttle body got crused), oil feed and return lines, FMU (12:1), blitz turbo timer, and also a greddy blue box for the obd-2 peeps...turbo needs new internal wastegate as the other one got bent.....very very very minimal shaft play (which is normal)...and very low miles....perfect condition....all that is needed to complete is the intercooler, BOV, upper intercooler pipe, and new wastegate.....asking $800 OBO
also FS (will get pictures soon) a JDM b16a2 swap with LS transmission....everything included with the motor to swap it out...mounts, ecu, motor, transmission, axels, sensors (a couple are broke), wiring harness.....this motor was in an accident but wasn't shifted or anything (this is how a couple of the sensors are broke).....everything is in tact...no broken mounts....good condition...roughly 55,000 miles on it...oil changed by the latest every 3,000 miles using 10w30 and honda oil filters...this motor WAS BOOSTED ON...but a new headgasket was installed (thicker cometic to lower the compression...the old one wasn't blown) only a few days before the accident and there was no sign of detonation..running very good...no blow by....has new timing belt, water pump, cam seals, and rear main seal...also has brand new ARP head studs....the LS tranny is rebuilt....shifts very smooth NO LSD....and yes this is legit...bought from Steve at hmotorsonline.com as of april of 2003....asking $2000 OBO
if you have any ?'s regarding anything...either PM me or shoot me and e-mail hybrid93sivic@yahoo.com
thanks
Adrian
pics can be seen at:
http://www.imagestation.com/album/?id=4286499977
Modified by hybrid93SIvic at 1:13 AM 6/20/2004
thanks
Adrian
bump....and if anyone wants to host some of the pics for me that would be greatly appreciated..i still haven't figure out that **** yet...
dcsports
Oct 7, 2004 07:48 PM
