AV-Engineering Stage3 H22a4
Old Aug 10, 2010 | 12:07 PM
qQQp's Avatar
Default AV-Engineering Stage3 H22a4
This is just to see if anyone is interested or for people planning on boosting. I would like to pass this to someone who's obviously serious about their build instead of getting a "done" car. The reason I'm putting up this for sale is that I gotta focus on school/moving out and this project really weighs me down.
First off, for past couple years I was planning on boosting my lude. I've contacted both laskey and av and decided to go with av.
most of you might know quaility of anthony's works so I'll keep it short.
www.av-engineered.com for those dont know.
Spec :
AV Engineering Stage 3 Port/Polish
Using stock valves/springs/ret.
Competition 3 angle valve job
Surfaced to a mirror like finish
Resurfaced Deck
new seals
hot tank/crack check
Complete Assembly
AV Engineering Shortblock Stage 3 - Rated at 550hp
ERL SuperDeck 1 Sleeves - Pressure tested at 45psi
(closed deck)
CP Pistons (Stock bore, .20 over additional, etc)
(Ring-End Gap Set specific to power goals)
Eagle Rods 3/8" ARP 2000 Bolts
CP Piston rings, wrist pins, locks
ACL Main/Rod Bearings and Thrust Washers (All
Clearances Measured)
OEM Honda Gaskets
OEM Honda Oil Filter
Block bored and final hone
Block hot tanked 4x
Align Hone
Block resurfaced
Stress Relief
Fully assembled
Polished Crank
BluePrints
Balance Shaft Removal Kit
-Complete LONGBLOCK assembly
OEM headgasket, Valve Cover, Cam Seals, Timing
Belt (where applies), Balance Shaft Belt (H series),
Injector O-rings, all other misc seals/gaskets/etc.
Valve Lash Set
All bolts fastened to specified torque
All components cleaned upon installation
Longblock Engine completely assembled and ready for installation
ARP Head studs
Honda H22 A4 VTEC head stud kit
OEM Water Pump Upgrade
OEM Oil Pump Upgrade
AV Engineering Modified Oil Pump
AV Engineering Blueprinted bottom end with Spec Sheet
AV Engineering Balance Shaft Removal Kit
Rotate Balance Shaft Bearings
ERL Polished Crank
Hondata HeatShield Intake Manifold Gasket
OEM Honda H23a Manual Tensioner Conversion Kit
Installation of H23a Manual Tensioner Kit and Skunk2(cam gears) Components
NGK BCPR7ES Spark Plugs
*Gap to .026"
AEM Fuel Rail - Silver
OEM Valve Cover Gasket Set
OEM Gasket, Throttle Body
Thermostat Assembly (OEM Honda)
Valve Assembly, PCV
Seals, Gaskets, Bearings, OEM parts, etc.
Cut Valve Cover for the cam gears.
Again, everything is fully assembled and ready to install.
6000$OBO+paypal+shipping. I won't ignore reasonable offers.
I'm willing to throw in s2k im(new) and its necessary components for free depends on offers.
DROPPED 5500$+Shipping.
Old Aug 10, 2010 | 06:50 PM
qQQp's Avatar
Default Re: AV-Engineering Stage3 H22a4
ttt
Old Aug 11, 2010 | 11:15 AM
qQQp's Avatar
bump
Old Aug 12, 2010 | 08:50 PM
qQQp's Avatar
tttttt
Old Aug 13, 2010 | 07:11 PM
qQQp's Avatar
bump
Old Aug 14, 2010 | 07:37 AM
qQQp's Avatar
tttt
Old Aug 15, 2010 | 04:55 PM
qQQp's Avatar
bump
Old Aug 17, 2010 | 07:15 PM
qQQp's Avatar
price negotiable!! ttt
Old Aug 19, 2010 | 01:13 PM
qQQp's Avatar
lets make a deal!! need it gone!!
Old Aug 21, 2010 | 09:10 PM
qQQp's Avatar
ttt
Old Aug 21, 2010 | 09:51 PM
fv8s's Avatar
this will make some great power. GLWS
Old Aug 22, 2010 | 05:36 PM
qQQp's Avatar
thanks, cmon guys this thing needs new home, lets work out a deal!
Old Aug 24, 2010 | 02:29 PM
qQQp's Avatar
bump
Old Aug 26, 2010 | 03:32 PM
qQQp's Avatar
ttt
Old Aug 27, 2010 | 10:02 AM
qQQp's Avatar
bumpttt..if price seems high pm me as im trying to work something out.
Old Aug 28, 2010 | 01:38 AM
H22a4 Searcher's Avatar
Nice! Love to have it.
Old Aug 28, 2010 | 08:04 AM
qQQp's Avatar
Thanks, weekend bump,,,
Old Aug 29, 2010 | 07:36 AM
qQQp's Avatar
bump!! lets make a deal!!
PRICE DROPPED!!5800+pp+shipping w/BRAND NEW SK2 IM!
Old Aug 30, 2010 | 09:24 AM
qQQp's Avatar
ttt
Old Aug 31, 2010 | 11:56 AM
qQQp's Avatar
bump
Old Sep 1, 2010 | 01:48 PM
qQQp's Avatar
ttt
Old Sep 3, 2010 | 11:14 AM
qQQp's Avatar
bump
Old Sep 4, 2010 | 08:34 PM
qQQp's Avatar
bump
Old Sep 6, 2010 | 09:58 PM
qQQp's Avatar
labor day bump
Old Sep 8, 2010 | 02:01 PM
qQQp's Avatar
back to mf top. offer anyone?
