Classic Hondas All Pre-1988 Hondas.
rack and pinion problems
Old Apr 30, 2010 | 07:44 PM
sanbernardghett's Avatar
Default rack and pinion problems
I recently purchased a 1987 crx si, everything was good until today when i was backing out of the driveway, i heard a loud clunk from the front passenger side, I put the car in 1st to pull over to the side and the front ride side makes a horrible noise, after a couple mins of play, i realize that the right tire barely moves (and grinds) when the wheel is turned all the way to the left or all the way to the right.
The tire isn't rubbing, but i think it might be my rack and pinion, what do you think? When the steering wheel is straight, the wheels roll somewhat, but when I turn the steering wheel either to the left or right, thats when the wheel locks up and makes a nasty grinding noise =[
Old May 1, 2010 | 12:18 AM
Gabe87CRX's Avatar
Default Re: rack and pinion problems
That is what it sounds like to me... OR you broke an axle....
Old May 2, 2010 | 06:31 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Have you checked the balljoint and tie rod end? Is the strut still attached securely top and bottom?
Old May 2, 2010 | 11:19 AM
E-AT_me's Avatar
sounds like your lower balljoint broke, which is common.
ApatheticAccord
Mar 12, 2016 01:48 PM
theguy22
22
Nov 6, 2011 10:58 AM
sanbernardghett
Apr 30, 2010 07:25 PM
pr0phet
Oct 21, 2005 11:54 AM
Nathan007
May 13, 2004 04:54 PM
