Classic Hondas All Pre-1988 Hondas.
d16z6
Old May 29, 2009 | 12:32 PM
spikez_crx's Avatar
Default d16z6
can i fit a d16z6 on a 87 crx si??
Old May 29, 2009 | 03:02 PM
E-AT_me's Avatar
Default Re: d16z6
yes. but there is no mount kit for it so you'd have to make your own. and it won't bolt up to the trans that is in the car now, so you'd need that. and axles and more than likely 86-89 integra hubs/spindles.
Old May 30, 2009 | 02:12 PM
spikez_crx's Avatar
Default Re: d16z6
im trying to put like a single cam v-tech on it or something similar to it. what do you recomend?
Old May 31, 2009 | 05:18 AM
E-AT_me's Avatar
Default Re: d16z6
you're going to run into all of the same problems. the EW/D15 that our cars have does not share anything with 88+ cars.
Old May 31, 2009 | 09:59 AM
spikez_crx's Avatar
Default Re: d16z6
so what do you recomend swaping?
Old May 31, 2009 | 11:52 AM
E-AT_me's Avatar
Default Re: d16z6
what are your goals and experience along with expectations?
Old May 31, 2009 | 11:53 PM
spikez_crx's Avatar
Default Re: d16z6
something not that expensive with an ok horse power.
maybe dual d16.
Old Jun 1, 2009 | 04:12 AM
E-AT_me's Avatar
Default Re: d16z6
a d16a1 out of an 86-87 integra will get you about 110-115 hp. you will need motor, trans, axles, knuckles/hubs, and ECU.
Old Jun 1, 2009 | 10:19 PM
spikez_crx's Avatar
Default Re: d16z6
what would be something above that?? a lil more better.
Old Jun 2, 2009 | 03:46 AM
E-AT_me's Avatar
Default Re: d16z6
well, if you can find one a JDM ZC. but you'd still need all the other teg parts. that would net you closer to 130hp. above that, you will need to do a b series as it would still probably end up being more cost effective than a D16z6 due to the fact you wouldn't have to fabricate anything.
Old Jun 2, 2009 | 07:57 AM
Bakeoff's Avatar
Default Re: d16z6
Its been a long time, but don't the 88+ D series bolt up to the d16a1 tranny, minus a couple bolts lining up?
Old Jun 2, 2009 | 08:02 AM
E-AT_me's Avatar
Default Re: d16z6
may be so, but the motor mounts are no where near the same which would then have to be fabricated. along with still needing the teg axles/knuckles etc..
Old Jun 2, 2009 | 08:57 AM
spikez_crx's Avatar
Default Re: d16z6
i think im do a d16. what about the mounts? is it direst bolt on? around how much are they?
Old Jun 2, 2009 | 10:46 AM
E-AT_me's Avatar
Default Re: d16z6
best bet is to find a running integra doner car that has a bad/rusty body. that way you can get everything you need.
Old Jun 2, 2009 | 03:44 PM
spikez_crx's Avatar
Default Re: d16z6
ight koo. is there any way that you could add v tech to it?
Old Jun 2, 2009 | 05:03 PM
E-AT_me's Avatar
Default Re: d16z6
no. there would have to be a VTEC head that would bolt on, and there is not one that i know of.
Old Jun 3, 2009 | 11:07 AM
spikez_crx's Avatar
Default Re: d16z6
oh i see. so as far as performance the easiest thing i could to its turbo. right??
Old Jun 3, 2009 | 12:28 PM
E-AT_me's Avatar
Default Re: d16z6
more than likely yes. i've heard that with a little bit of work, the old Greddy SOHC turbo kit will bolt up, but i'm not 100%.
Old Jun 3, 2009 | 10:06 PM
spikez_crx's Avatar
Default Re: d16z6
do i have to sleeve the block or something?
Old Jun 4, 2009 | 03:58 AM
E-AT_me's Avatar
Default Re: d16z6
that is beyond my knowledge.
Old Jun 4, 2009 | 10:43 AM
spikez_crx's Avatar
Default Re: d16z6
alright thats cool then. well thanks for the help i really apprecciate
Old Jun 6, 2009 | 02:09 AM
vtecn8ive's Avatar
Default Re: d16z6
v-techhhhhh
Bipolarcivic
Jun 23, 2013 02:09 PM
phrack3r
Feb 2, 2010 08:29 PM
del sol1658
Aug 26, 2006 03:04 PM
posterfee
Jan 12, 2006 07:54 PM
jdmCivic925
Jul 15, 2005 11:24 AM
