Classic Hondas All Pre-1988 Hondas.
converting to fuel injection?
Old Jun 19, 2010 | 11:41 AM
allmotorRyan's Avatar
Default converting to fuel injection?
ok so im working on putting a ls vtec into my 86 crx my buddy has a full obd0 b16a coversion harness for a 88-91 civic can i use this? i already have a obd0 b16 head and a obd0 ls block with lsvtec kit i ordered the mounts what linkage do i use? any other advice woudl help like fuel pump sugesitons how do i go about that ?
Old Jun 26, 2010 | 07:03 PM
hondub's Avatar
Default Re: converting to fuel injection?
I'm here searching for the same reason. I dont think that the conversion harness is going to match the dash harness. Im thinking about using a junkyard ef dash harness and modifying stock linkage using ef parts. Good luck
Old Jul 12, 2010 | 09:32 AM
rocksparow's Avatar
Converting to Fuel Injection
What is fuel injection?
Why should I Convert to Fuel Injection?
What does it do?
How hard is it to install?
What parts do I need?
How expensive is it?
What are the benefits?
Old Jul 12, 2010 | 06:28 PM
E-AT_me's Avatar
is your CRX fuel injected already? if no, then you will need a lot of parts. either way, the harness won't work.
Old Jul 18, 2010 | 09:05 AM
i ended up getting a full obd0 da harness and it plugs rite into the dash harness then all u need to do is run vtec its 2 wires but u would need a obd0 engine and vtec ecu unless u covert to obd1
Old Jul 24, 2010 | 10:29 AM
85WagonMan's Avatar
As far as the fuel pump grab a complete pump and hanger assembly out of something like a 87-88 integra It will have to be wired in. You will also have to run a fuel return line back to the tank from the fuel rail.
shuttle xer
12
Sep 24, 2019 09:02 AM
90civicbns
Jul 17, 2013 11:41 AM
KyleVA
Jan 1, 2007 11:37 AM
Suck my DX
Aug 24, 2005 08:29 PM
