Classic Hondas All Pre-1988 Hondas.
1969 S800M Coupe.
Old 12-24-2017, 01:01 AM
  #476
Jochem's Avatar
Default Re: 1969 S800M Coupe.
deutschland ruft an
File Type: mov
Old 12-25-2017, 05:13 AM
  #477
Vanishing Point's Avatar
Beautiful S800 Jochem....... how long have you had the car and did you purchase it or restore the S yourself?
Old 12-25-2017, 01:46 PM
  #478
288GTO's Avatar
Do agree, but from appearance she's more like early S600, no ?
Old 12-25-2017, 09:03 PM
  #479
AussieAS285's Avatar
I am going with German market S8, but for some unknown reason an S6 front grill. Very interesting colour, I like it.
Old 12-30-2017, 12:02 AM
  #480
Kuroneko's Avatar
Gorgeous color!
​​​​​It looks perhaps like an early 911 color. Looks a little light too be the 356 gray?
If I ever get to repainting my Coupe, I've been looking at similar shades...
Danke for posting.
As well as being out with the Speedhunters - Project NSX, we visited the last Tokyo Bayside Classic Cup of the year, and again watched the marvellous benefit of mid-engined handling with both an S500 and an S600 equipped T360 trucks running slicks bettering many others from the same era. They lacked straight line speed, but it's pretty neat watching them pass much bigger cars around the outside of corners!
On the way to Sodegaura Raceway, taking in the Boso Skyline:
On the way home, with the setting sun in Shibuya-ku:
Old 01-03-2018, 03:06 AM
  #481
Jochem's Avatar
Hello,
i drive this car since 1983 and i restore this s by myself
Old 02-16-2018, 12:38 AM
  #482
Kuroneko's Avatar
Out for a car-swapping drive with a friend and his S660.
Modded by Spoon with a bigger turbo and a wicked pop-off valve right behind the driver's head, with well over 100PS it is an absolute blast to drive.
Funny too, it feels a lot like a S800 at city speeds, but a lot more neutral into the corners.
Better brakes too!
Old 03-18-2018, 11:58 PM
  #483
Kuroneko's Avatar
S800M lightweight Coupe with a staring role on Speedhunters.
Quickly followed by their Project NSX.
The Spoon S660 was great to drive, but the NSX was just spectacular...
Do You Hond?
Old 03-25-2018, 09:29 PM
  #484
Marcos Barrios's Avatar
I hond
when i saw the picture with the t360 trucks
ahhh man that brought back some memories ^_^
my Sofu used to have a T500 flatbed that he used on the family rice farm in Osaka when i was growing up but he traded it back in 96ish for a hilux pickup
so Neko any updates on the S800 lately
Old 04-08-2018, 07:17 PM
  #485
Kuroneko's Avatar
Updates?
Sort of...
Bolt number 18, securing the alternator broke off, just below the surface of the engine block.
Not even the Neji-Saurus was going to be able to get it out.
Drilling, and a bolt extractor were then attempted. Then this happened:
The bolt was shorter than expected, and shorter than the hole (perhaps why it broke too).
When the drill passed through, with the pressure I was using, the 2.8mm drill broke off.
I was now looking at drilling the drill bit. A 3.0mm drill made an awful noise, but allowed me to hammer a screwdriver into what remained of the bolt, and simply screw it out.
Two new hi-tensile hex bolts, of proper length, now secure my alternator mount to the aluminum block. Careful to not over torque, but use strong spring washers.
Hopefully secured properly now.
I had taken off the S800 windshield wipers as the replacement blades did not fit the arms properly, and one of the arms was loose on the spindle - with the added benefit of saving weight.
With shaken booked for this week, I needed to reinstall, so retapped the arm and installed an oversize bolt to secure the arm to the wiper spindle, and Dremelled out the replacement blade to match the arm mounting lug.
Plus, I've had to spend a bit of time driving to test the new horn button...
Old 04-08-2018, 07:28 PM
  #486
-Intl Steve Krew
Caoboy's Avatar
How strenuous is shaken?
Old 04-08-2018, 07:44 PM
  #487
Kuroneko's Avatar
That depends!
Click here for a good overview on the process and options...
You can guess what I am doing.
Old 05-06-2018, 04:13 AM
  #488
S500 pictures from Spread Tool.
https://box.yahoo.co.jp/guest/viewer...8-5ce3334bd1be
Old 05-21-2018, 05:00 AM
  #489
Kuroneko's Avatar
That's a nice 500, I should check where it is now...
My differential has started to make more noise than usual.
Investigation suggests there are two types of 800M diff:
Early taper bearing diff, replaced with later cheaper needle roller bearings.
The needles wear faster I assume, and not sure if you can tell from the outside housing...
Assume because mine is late 800 (last 400 built I think) it would be needle.
Wear and noise suggests it is too...
Now, to get parts!
Old 05-21-2018, 05:02 AM
  #490
Kuroneko's Avatar
Get out and drive... noisy diff included.
Old 06-12-2018, 04:59 AM
  #491
Kuroneko's Avatar
Hibiya.
Still no diff work, but more playing chase to NSX...
Coffee shop start.
R246.
R246.
Tsukiji,
Old 08-08-2018, 03:38 AM
  #492
Kuroneko's Avatar
Shimbashi Nakagin Biru
Old 08-10-2018, 09:27 PM
  #493
Capsule hotel ??
Old 08-13-2018, 03:12 AM
  #494
Kuroneko's Avatar
Originally Posted by AussieAS285
Capsule hotel ??
Sort of, but not really.
Its the Nakagin Building, an example of Japan's view of the future that had no future.
An apartment / office building, with supposedly replaceable pods.
Which turned out to be too small for any real use, with limited services like heating and cooling.
Damn gorgeous building though!
Its supposed to be repaired, re-podded, or pulled down. None of which appears to be happening.
You used to be able to visit the model room and explore, but tourists with no manners have killed that off...
Old 08-24-2018, 09:54 PM
  #495
Kuroneko's Avatar
Unfortunately, with a new car on the way and due to lack of parking, I have to sell my S Coupe.
JPY3,300,000 plus shipping (West Coast US estimate USD1500 ro-ro, UK USD1700. Container, add USD 750-ish).
The body needs attention (rust spots photographed in detail if anyone here seriously interested), as well as the details here, this is a brief summary of work to date:
Honda S800 Coupe
Replaced
Engine overhaul
Gearbox selector overhaul and gear inspection
Full stainless exhaust
Horns
Clutch
Alternator (no regulator)
Electronic distributor
New Coil
Long wheel studs
RS Watanabe wheels
Fuel tank sender
Speedmeter cable
Throttle cable
Radiator and cap
Thermostat
Cam shims
Yokohama tires
Carburetor overhaul with new gaskets, jets, and o-rings
Carburetor mounts
Air cleaner
Oil filter mount
Brake cylinder seals
POR15 rust proofed floor
Sound deadener
Indicator can
H4 100W headlamps and relay set
LED instrument lighting
Pop out window and rear hatch seal
Wide-H shift **** and horn button
FRP matte black hood
Safety seat belts
Relocated hazard switch
Fuse box
ETC
Leather / aluminum handle
AVO fully adjustable shock absorbers
Front torsion boots
Front torsion bar adjusters
Fuel cut-off solenoid
Front carpets
8-day Auricoste 36-9 aircraft clock c.1969 (from Sud Aviation Caravelle)
Spares
Door seals (not fitted)
Door scrapers (not fitted)
Fuel pump (not fitted)
Oil catch tank / breather box (not fitted)
Ashtray trim (not fitted)
‘Honda’ AM / FM / Cassette (not fitted)
Chrome front and rear bars (not fitted)
Air cleaners (not fitted)
Oil filters (not fitted)
Spare wheel (not fitted)
Spare wheel carrier (not fitted)
FCR flat slide carburetors (not fitted)
Koni rear shock absorbers (not fitted)
Oil filter spanner
STE Unisync carb air flow meter
Old 08-25-2018, 07:15 AM
  #496
Blue-Civic-Hybrid's Avatar
Looks like I will have to sell a kidney very soon... That is an amazing price!
Old 08-25-2018, 10:51 AM
  #497
-Intl Steve Krew
Caoboy's Avatar
Old 08-25-2018, 05:02 PM
  #498
Kuroneko's Avatar
Hai... I feel the same.
The price reflects the need for some rust repair on the front fenders - it has the usual front window lower pinch weld corrosion, and consequent build up of moisture inside the front fenders. Perforation is occurring, but I've stopped the window seal leaking, so it's really not getting any worse.
However, this is an easy fix, and there is no structural damage, including the frame and floors as you can see from earlier pics.
​​​​​​I hope someone buys the car to drive it, as in Japan they passed the point of drivers to collectors a few years ago, and I do not see them driven any more...
(There are four options for the fenders; leave and drive, FRP, patch repair, steel OEM replacements.)
Neko
Old 08-25-2018, 06:02 PM
  #499
-Intl Steve Krew
Caoboy's Avatar
That car is a collector now anywhere...
I’m just sad I won’t see anymore updates on it.
What are you replacing it with?
Old 08-25-2018, 09:14 PM
  #500
Many of us will miss photos of the car itself, but more, we will miss the interesting backdrops to each image.
Quick Reply: 1969 S800M Coupe.
