Would this work??
Old Apr 7, 2007 | 08:01 PM
JDM_SOHC's Avatar
Default Would this work??
I have a 94 dx coupe, but JDM conversion is about 70% complete im just throwing little things on here an there, an i came across this on Ebay, and im not sure if it would work in my car or if i could get it to work in my car somehow... Any help's appreciated...
http://cgi.ebay.com/ebaymotors...ZWD1V
Old Apr 7, 2007 | 09:33 PM
MestizoRacer310's Avatar
Default Re: Would this work?? (JDM_SOHC)
You won't get radio reception because we use a different "system" or uhm, frequency than they do in Japan. I think there may be an adapter out there that converts it so you can listen to US radio stations on it....
Old Apr 8, 2007 | 04:01 AM
perseverance's Avatar
i think u need an fm expander for it... u can get one at radioshack i believe and just solder it in.
Old Apr 8, 2007 | 05:57 AM
fcm's Avatar
fcm
Old Fart
Yes it will work, you will need one of these... http://www.catronics.com.au/fmconverter.html 94
Old Apr 8, 2007 | 07:30 AM
JDM_SOHC's Avatar
Default Re: Would this work?? (fcm)
and as far as the plugs in the back working??? would i have to re-wire anything or add any wires in??? i've never tried to install an OEM cd player out of another year/make/model into my car before so i didnt kno the specs on it, but i appreciate that FM transmitter link..
now if i only could find out if it actually would work, thatd be awesome..
Old Apr 8, 2007 | 09:33 AM
B18C_EJ8's Avatar
If you have a '94 and that's out of a '96 or later, then no, it won't be plug & play. You'll need the reverse harness (Metra Part Number 71-1721) and the regular wiring harness adapter for your vehicle (70-1720). Wire them together matching color to color and then it will be plug & play.
Mounting the unit, however, may require some creative engineering.
Old Apr 9, 2007 | 10:50 AM
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">If you have a '94 and that's out of a '96 or later, then no, it won't be plug & play. You'll need the reverse harness (Metra Part Number 71-1721) and the regular wiring harness adapter for your vehicle (70-1720). Wire them together matching color to color and then it will be plug & play.
Mounting the unit, however, may require some creative engineering.</TD></TR></TABLE>
Yeah, I did that on my wagon when I put a newer (blue plugged radio) into my '95 (gray plugged) wagon. I took a normal harness you would hook up to an aftermarket radio and then got a reverse harness for the 98up Honda harness...also referred to as a "repair harness". It was all plug and play from there. Unfortunately I ran out of time to figure out how to physically mount it inside and it was just held in by the black bezel console.
I now have an Alpine h/u and couldn't be happier. (Well maybe happier with better speakers..haha)
Old Apr 9, 2007 | 11:26 AM
fcm's Avatar
fcm
Old Fart
Actually, it will be the same plug from 86 - 98/99. 94
Teg44
Mar 25, 2003 05:32 PM
roninb18
Feb 26, 2003 11:27 AM
fastwanabe
Oct 22, 2002 07:50 PM
