Would this be possible?
Old Jan 5, 2005 | 02:46 PM
killaBc1's Avatar
Default Would this be possible?
I was looking at The Jl 6w0, and was thinkin about mounting these where my rear speakers would go, just use sum sound deadning materail as a sealer.. My car is a 97 integra. My goal is to have sum bass but without subs with a box. Run a small amp, would this be possible without "major" Modifaction? or has ne1 ever done this?
Old Jan 5, 2005 | 03:31 PM
99IntegraGS's Avatar
Default Re: Would this be possible? (killaBc1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlaudio.com &raquo;</TD></TR><TR><TD CLASS="quote">The 6W0 opens up a world of custom installation possibilities. This small driver is a true subwoofer with excellent low-frequency extension in very small enclosures. The 6W0 is small enough to be integrated under dashboards, inside custom consoles and in many other applications only limited by your imagination. It is not intended as an infinite-baffle speaker (our XR650-CW component woofer is better suited for that application.)</TD></TR></TABLE>
According to the spec sheet, the 6W0's ahould be in one fo the following enclosures:
Sealed Enclosure Range: 0.15-0.20 cu.ft. (4.3-5.8 liters)
Ported Enclosure Range: 0.20-0.33 cu.ft. (5.8-9.3 liters)
I think it would be interesting to try to make a small enclosure and mount it behind the metal where the plastic speaker mounting brackets go. I wouldn't think the results would be very good doing what you suggest.
JD
Old Jan 5, 2005 | 04:00 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killaBc1 &raquo;</TD></TR><TR><TD CLASS="quote">I was looking at The Jl 6w0, and was thinkin about mounting these where my rear speakers would go, just use sum sound deadning materail as a sealer.. My car is a 97 integra. My goal is to have sum bass but without subs with a box. Run a small amp, would this be possible without "major" Modifaction? or has ne1 ever done this?</TD></TR></TABLE>Yes it is possible, but as 99IntegraGS said....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99IntegraGS &raquo;</TD></TR><TR><TD CLASS="quote">
JD</TD></TR></TABLE>You will need enclosures, there is a fair amount of room back there, I have made .5 cu.ft. fiberglass enclosures, [sealed] for the stock rear speaker locations 94
Old Jan 5, 2005 | 08:39 PM
JAI-DM's Avatar
Im going to do the same thing in my 01 Teg but with JL8W0's. Build a box for the speakers or else your not going to get the sound your after. Afterall the only real "box" would be the plastic paneling.
Old Jan 5, 2005 | 08:49 PM
zumiez007's Avatar
Default Re: Would this be possible? (fcm)
sound deadoning material as a sealer? Use it to deaden the sound/vibrations, but not as a sealer. You use weatherstriping to make the seal between the enclosure and the subs.
Old Jan 6, 2005 | 02:25 PM
killaBc1's Avatar
Thanks for the replies, but how would i go about making a box to fit in there? i want to do this setup, but i dont feel like payin out of my *** for a custom job, rather have it as a project on my own.
Old Jan 6, 2005 | 05:43 PM
PupaScoopa's Avatar
Simply being able to isolate the back wave from the front would be sufficient for some sound quality. You won't get "sub bass" but it'll sound like a good set of mids. If you wanted to build an enclosure, you can probably get creative with some MDF. Check a cabinet shop and see if you can score some scrap birch plywood, whcih is also an excellent enclosure material. I doubt you'll be able to find this in less than 1/2" thicknesses though. I would think that 1/2" enclosure material is overkill for some 6" or 6.5", you may not have an alternative.
I wouldn't suggest making the enclosure and trim panel a permanent piece. Instead, make the enclosure without a speaker baffle, that is without a front piece of wood with a hole in it for the speaker. Seal the enclosure to the back of the panel (tricky, since that panel probably has curves. Then, mount the speaker to the trim panel with some reinforcement to the enclosure.
I'm sure there's an easier way!
JDMThoughts
Audio / Security / Video
Dec 14, 2005 05:20 PM
suzawa94
18
Oct 24, 2005 07:41 PM
JDubya
36
Sep 19, 2005 07:22 AM
Intercooler
10
Dec 2, 2004 08:13 AM
NVBAM
Jul 20, 2004 10:16 PM
