Wiring multiple sirens
Old Mar 21, 2005 | 07:46 PM
Junkie Si's Avatar
Default Wiring multiple sirens
just wondering how would u go about wiring up 3 or 4 sirens to an alarm...can u just wire all the sirens to the siren output? ? ? i'm going to be wiring up 2 sirens under the hood and a little pain generator siren inside the car...any help will do...thanks
Old Mar 21, 2005 | 09:37 PM
SuckMyDOHC's Avatar
yes.. all to the same output
Old Mar 22, 2005 | 08:07 AM
nsxxtreme's Avatar
It depends on the ouput capabilities of the alarm output at some point you need to add a relay. Refer to your alarm documentation to figure out when to do this.
Old Mar 22, 2005 | 09:24 AM
fcm's Avatar
fcm
Old Fart
Default Re: (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">It depends on the ouput capabilities of the alarm output at some point you need to add a relay. Refer to your alarm documentation to figure out when to do this.</TD></TR></TABLE>Ditto that.......... also check and see if your alarm has an alarming output, if so wire extra sirens to it , [with relay if needed] that way the extra sirens only go off when the alarm is tripped not when arming and disarming 94
Old Mar 22, 2005 | 09:52 AM
SuckMyDOHC's Avatar
yes but with 3 sirens it should be fine
Old Mar 22, 2005 | 06:57 PM
fcm's Avatar
fcm
Old Fart
Default Re: (SuckMyDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">yes but with 3 sirens it should be fine</TD></TR></TABLE>Depends on the alarm, if one of the siren draws 3amps, [non electronic] you could blow the siren output of the alarm 94
HyphyMovementZ
Audio / Security / Video
Dec 20, 2008 09:04 PM
lilmike
19
Apr 8, 2006 12:56 AM
SamC
Nov 25, 2002 10:16 PM
mikecel79
Oct 29, 2002 06:20 PM
