Wiring a Head Unit
Old Nov 1, 2005 | 09:21 PM
concept11253's Avatar
Default Wiring a Head Unit
When you wire your head unit directly to the battery, which terminal do you use? I am assuming the positive terminal?
Old Nov 1, 2005 | 11:04 PM
Ford no more's Avatar
Default Re: Wiring a Head Unit (concept11253)
From one nOOb to another... Yes.
The Positive (+) red terminal is nominally +12volts, the negative (-) black terminal is ground -- connected to the vehicle's chassis.
Typically head units don't draw so much current that they need to be connected directly to the battery... unless you have some particular reason for doing so.
Lastly, INSTALL A FUSE!!! (Preferably near the battery.)
Old Nov 2, 2005 | 10:18 AM
fcm's Avatar
fcm
Old Fart
Default Re: Wiring a Head Unit (Ford no more)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ford no more &raquo;</TD></TR><TR><TD CLASS="quote">
Lastly, INSTALL A FUSE!!! (Preferably near the battery.)</TD></TR></TABLE> You are right about the fuse, however, more and more of today's "high power" HU require more currant then the oem constant power can supply, most Honda/Acuras oem radio harness constant power is fused at 7.5A, most newer HU need at least 10A on the constant input, [yellow] line. At the same time the oem ground wire is not adequate, so grounding the HU directly to the chassis, or adding a ground from the chassis of the HU to the chassis of the car is needed to get the full performance out of the internal amps in today's HUs. 94
Old Nov 2, 2005 | 02:18 PM
Default Re: Wiring a Head Unit (fcm)
haha, Thanks. This is my first time dealing with car electrical systems. My Head Unit has a 15A fuse built in.
Old Nov 3, 2005 | 11:31 AM
fcm's Avatar
fcm
Old Fart
If the stock Hu is still in your car, get the Metra harness adpt. for your car, jerk out the yellow lead out of the adpt, harness, all the other connections from the HU harness to the adpt harness will be color for color, [easy as cake, piece of pie] run the fused line from the batt, and connect that to the HU yellow, like I said, it will be almost "plug and play". 94
Old Nov 4, 2005 | 02:31 PM
Thanks, It was pretty much cake compared to alot of other things I have done to my computer. I ended up wiring it into my cig lighter.
Old Nov 5, 2005 | 07:16 AM
fcm's Avatar
fcm
Old Fart
The lighter power wire is no better then the radio harness power wire 94
DarkBB4
Jun 13, 2007 10:19 AM
d412k5t412
Audio / Security / Video
Oct 11, 2006 08:44 AM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
slow motion
Aug 7, 2004 03:04 PM
araknis
Jan 21, 2003 09:53 AM
