wire harnessing
Old Dec 31, 2002 | 11:35 AM
hagrid's Avatar
Default wire harnessing
i'm trying to install my new h/u. im looking at the wires that come from the car the guy before me decided to chop up. and theres no yellow with red stripe wire which is the +12 volt ignition wire. is that why i'm not getting any power to the h/u? where does that wire come from? need people guys. thanks
Old Dec 31, 2002 | 12:41 PM
hagrid's Avatar
Default Re: wire harnessing (5th Gen)
Old Dec 31, 2002 | 01:45 PM
Desslok's Avatar
They should all be in the same loom of wires. DO you have a test light or meter?
Old Dec 31, 2002 | 09:58 PM
hagrid's Avatar
Default Re: wire harnessing (sp)
nah i don't. but what would be the point of having the tester if i dncn't evn find rrhe freakin wire lollz...what would i ber testing? rerxufse my typing cause i'm pretty drunhk riihgt now
Old Dec 31, 2002 | 11:20 PM
clm's Avatar
clm
www.installdr.com - that should help.
Old Dec 31, 2002 | 11:36 PM
hagrid's Avatar
Default Re: wire harnessing (clm)
still can't find my yellow with red stripe
Old Jan 1, 2003 | 07:57 PM
95CoupinIt's Avatar
pull out your multimeter and go to the ignition harness and run a new ignition (switched) wire from the ignition harness to the radio cavity. i can't remember what color it is...for some reason i want to say black/yellow. i just cant remember exactly. but meter it, fuse it, and then you are all set. this is a good way to do it if u cant find the wire in the radio cavity. lemme know if u need more insight on this topic....
Old Jan 2, 2003 | 04:22 AM
hagrid's Avatar
Default Re: wire harnessing (95CoupinIt)
where is the multimeter? where is the ignition harness? sorry i sound like such a noob.
Old Jan 2, 2003 | 12:51 PM
vteg's Avatar
New User
You use the multimeter to measure voltage. A cheap one will work for your situation. Basically you would check the voltages on the wires with the ingnition off, then put the ignition switch to accesory and check again. The one that goes from nothing to +12 is your wire.
90_EX_Civic
Mar 21, 2009 07:59 PM
ATL_gingerkid
Feb 17, 2007 10:46 AM
BoostedJeff
Jan 30, 2005 05:10 PM
honda06si
14
Nov 3, 2004 08:37 AM
Trigun
Apr 18, 2002 03:26 AM
