Windows Automatically roll up Alarm Module.
Old Jun 12, 2004 | 07:32 AM
plusONE jboy's Avatar
Default Windows Automatically roll up Alarm Module.
Well I have that module that when you arm your alarm the windows automatically roll up.
I had a question, last night it just stopped working.. How would I troubleshoot this to fix this problem?
Where might it be broken?
Old Jun 12, 2004 | 07:47 AM
ASHY-ELBOW's Avatar
Default Re: Windows Automatically roll up Alarm Module. (j boy)
first check the fuse on teh module itself, wherever they mounted it , if its not that it might be a faulty module, or maybe your ground when armed wire came loose or disconnected
Old Jun 12, 2004 | 06:26 PM
Default Re: Windows Automatically roll up Alarm Module. (ASHY-ELBOW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASHY-ELBOW &raquo;</TD></TR><TR><TD CLASS="quote">first check the fuse on teh module itself, wherever they mounted it , if its not that it might be a faulty module, or maybe your ground when armed wire came loose or disconnected </TD></TR></TABLE>
Cool man thanks for the reply.. I located where the fuse is that will be the first thing to replace/check on.
I wouldnt be able to tell if its blown or not so I think i'll just replace that.
Hopefully thats the only problem..
Old Jun 13, 2004 | 07:52 PM
philly-O's Avatar
you can ground the input wire to test it, sometimes the 200ma output of the alarm isnt enough to activate the modules. if that is the problem, just add a relay to beef up the ground signal.
Old Jun 14, 2004 | 09:11 AM
itr_dc2's Avatar
Default Re: Windows Automatically roll up Alarm Module. (peichie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peichie &raquo;</TD></TR><TR><TD CLASS="quote">just add a relay to beef up the ground signal.</TD></TR></TABLE>
How would adding a relay beef up the ground signal? A relay switches when it gets a 12v source to output a 12v to another device, IE an actuator or switch. If he has power windows already, there is definitely a relay in there from the factory. Adding another relay already to make a beefier ground...why the **** would he need to add another relay? That makes no sense whatsoever man.
Old Jun 14, 2004 | 09:49 AM
philly-O's Avatar
Default Re: Windows Automatically roll up Alarm Module. (itr_dc2)
the relay would be used to make the ground signal from the alarm brain to the window module stronger. i have had to do this many times before since alarm outputs are usually only 200 milliamps. the way you would hook it up would be:
86 12v
85 ground switch from alarm
87 grounded
30 output to window module
a relay can be used for many different things, other than a switch.
Old Jun 14, 2004 | 09:52 AM
itr_dc2's Avatar
You numbers are right, just never heard of it making a stronger ground signal. Only thing i know is to make a better ground is to move it to unpainted metal. What you are saying now makes sense somewhat, but still wouldn't use a relay just to make a better ground. I would just relocate it. for future info
Old Jun 14, 2004 | 09:56 AM
philly-O's Avatar
if the ground output (signal from alarm to activate module) isn't strong enough to activate the module all the time, a relay is needed to make the signal stronger. the alarm's output will now activate the relay which in turn puts out an actual ground signal to the module. in no way are you upgrading the ground for the actual alarm, just the output signal. hope this clarifies.
Old Jun 14, 2004 | 10:06 AM
i still havent had a chance to check out the fuse.. i have aftermarket power windows. i hope that the relay that i think it is is for the auto up module and not the power windows.. but we will see.. today i am going to change the fuse.
Old Jun 14, 2004 | 10:34 AM
Alright guys I ran into a problem.. The fuse that I thought was for the Auto Up module was actually for the power windows..
Where would the fuse for the auto up module usually be located? Inside of the door panel? under the dash?
Old Jun 14, 2004 | 04:41 PM
ASHY-ELBOW's Avatar
it will be usually a few inch's from the module itslef, and if the ground is not strong enough, u can do what he suggests above about the relay, he read the thread and knows what he is talking about, but the other remarks
Old Jun 14, 2004 | 04:44 PM
ASHY-ELBOW's Avatar
and another thing, if u are using one of them aftermarket window kits like u said, sometimes there is no limit switch's/clutchs' on those kits for the alarm window module to read that good, wich in turn puts a strain on the alarm/window module , and after time will blow the fuse. how long have you had the alarm/window automation module installed ?&gt;
Old Jun 14, 2004 | 04:56 PM
Over a year installed..
Also I have no idea where they installed the auto up module.. i know where the fuse is for the aftermaket power windows.. but i dont know where the auto up module is installed at..
Old Jun 15, 2004 | 05:11 AM
ASHY-ELBOW's Avatar
usually they install them in the kick panel area, or inside the door it self at the switchs
Old Jun 15, 2004 | 07:59 AM
thanks man.. i'll try and find them..
Old Jun 21, 2004 | 08:33 PM
no luck, i found what appears to be the sensor.. is it a black box, with a harness holding a fuse on it?
if so i tried swapping out that fuse but still wont work.
Old Jun 22, 2004 | 07:20 AM
ASHY-ELBOW's Avatar
hmm, where was the box? can u read me the numbers on it, and whne u arm your alarm do you feel that box click inside?
Old Jun 22, 2004 | 06:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASHY-ELBOW &raquo;</TD></TR><TR><TD CLASS="quote">hmm, where was the box? can u read me the numbers on it, and whne u arm your alarm do you feel that box click inside?</TD></TR></TABLE>
Thanks for the help, I'll try and read the numbers off the box that I think is the module.
The box was behind the fuse box in the drivers side.
also.. what I tried to do was replace that fuse, with a spare fuse that was inside of the fuse box. The spare fuse said it was a 10A. on the module the fuse said 10. I dont know if that makes a difference or not.. Still didnt work though
Modified by j boy at 7:53 PM 6/22/2004
Old Jun 25, 2004 | 12:13 AM
STEV3-O's Avatar
same thing happened to a guy at work in his mustang, i was the fuse that keept going out, he mounted his in the door, take out your door panel and look to see if their is a fuse their as well, also if it aint that then it could be the module, they tend to go bad If u got a bad one hit me up, i might be able to get one for cheap, working as a stereo installer helps sometimes
Old Jun 25, 2004 | 12:17 AM
Default Re: Windows Automatically roll up Alarm Module. (sleepingeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingeg6 &raquo;</TD></TR><TR><TD CLASS="quote">same thing happened to a guy at work in his mustang, i was the fuse that keept going out, he mounted his in the door, take out your door panel and look to see if their is a fuse their as well, also if it aint that then it could be the module, they tend to go bad If u got a bad one hit me up, i might be able to get one for cheap, working as a stereo installer helps sometimes </TD></TR></TABLE>
thanks for the reply man, i will take apart my door panels on my day off.
Old Jun 28, 2004 | 06:08 PM
checked door panels, the module was not installed inside. anyone have any ideas?
Old Jul 12, 2004 | 10:52 PM
still havent found the module, or solved the problem..
Old Jul 12, 2004 | 10:57 PM
hybridzOr's Avatar
how hard is it to install one of these modules? is yours for auto roll up and down?
Old Jul 12, 2004 | 11:12 PM
Default Re: Windows Automatically roll up Alarm Module. (Hybrid Racer.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Racer. &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to install one of these modules? is yours for auto roll up and down?</TD></TR></TABLE>
I woudnt know i didnt install.. and mine is just the module when you arm your alarm the windows automatically roll up.
Old Nov 28, 2004 | 11:35 AM
its an old thread, but i didnt want to make a new one..
I cant find where this is installed, and the place that i had it installed at is pretty far from where i am at.. Anyone have any suggestions?
