Window Removal Break Ins ???
Old Jan 4, 2003 | 06:21 AM
greyzone's Avatar
Default Window Removal Break Ins ???
Anybody heard of theiving bastards removing front or rear windows to break into Civics (96 to 98)??
Or, possibly popping out the sun/moon roof glass??
I'm wondering about other ways they can get in without breaking glass or opening the doors....
LET ME KNOW WHAT YOU KNOW,
thanks
[Modified by greyzone, 2:03 PM 1/4/2003]
Old Jan 4, 2003 | 02:17 PM
x00gsr's Avatar
Default Re: Window Removal Break Ins ??? (greyzone)
Actually you don't even have to break the window. FOr example my Teg was broken in to through the passenger window. They just pryed the window just a little bit just enought to stick a coat hanger and pull on the power door lock switch. I guess for 96-98 honda civic the driver side is more vulnerable.
Old Jan 4, 2003 | 04:09 PM
civicmark's Avatar
Default Re: Window Removal Break Ins ??? (x00gsr)
this is how i had to unlock my bro's rex when he left the keys inside...
Old Jan 4, 2003 | 04:36 PM
greyzone's Avatar
Default Re: Window Removal Break Ins ??? (civicmark)
right, but that is still opening the door, which triggers the alarm...if the window is removed, and they climb in that way, they never open the door.
Old Jan 4, 2003 | 04:53 PM
philly-O's Avatar
they might not open the door but deffinately will set the shock sensor off.
Old Jan 4, 2003 | 05:58 PM
civicmark's Avatar
Default Re: Window Removal Break Ins ??? (peichie)
My shock sensor is only set off from sudden jolts/hits to the car. (If you slap it, it'll go off, but if you give it a small, slow, rock it wont. So if you slide in smooth enough it wont go off, but that's where the proxy sensor comes in
Old Jan 4, 2003 | 07:42 PM
greyzone's Avatar
thats exactly right, maybe thats what i need is a proxy sensor inside the vehicle...do you have any more information of that??
I figure im going to put an electromagnetic switch on the center console cause you know thats always the first place they go to see if your face plate is there..then that would trigger the alarm...but the proxy sensor would do it much better, but i need more information on that.
Nice thing tho is the magnetic switch is 4.99 at Radio Shack.
[Modified by greyzone, 8:44 PM 1/4/2003]
Old Jan 4, 2003 | 07:53 PM
civicmark's Avatar
the proxy sensor i have does this:
If you are standing within 3 feet of my car for more than about 5 seconds, it'll beep at you. If you actually stick your arm inside the car, it will fully go off. This is great for leaving the windows down in the summer
GraphiteMW
Jun 22, 2009 05:26 PM
Lightsped
Aug 28, 2008 11:14 AM
JDM custums
Nov 16, 2006 04:24 PM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
RATEDR
May 23, 2002 06:39 AM
