Where to mount shock sensor??
I'm installing my first alarm system. Where is the best place to mount the shock sensor? I have to mount it on a vertical surface with sheet metal screws. Since it is a stealth install, I'd like to keep it out of eyesight.
FYI, Clifford G4 alarms are crazy nuts to install.
sounds like you got an omni sensor
you can mount the sensor on the bracket in the center console depending on the car you have take the bezel around the radio off or the console and you should see a braket on each sidethat you can mount it on to but be carefull that your screws aren't to long because some cars have wires going up and downthat console.
good luck.
good luck.
Xxcivic99xX
Audio / Security / Video
13
Mar 27, 2008 05:18 AM
