Shock Sensor mounting location
Old Mar 4, 2005 | 11:48 AM
pdiggitydogg's Avatar
Default Shock Sensor mounting location
Aww...Search is down
Where is a good place to mount the shock sensor for my compustar?
I want to mount as much as I can before taking it in for the wiring so they charge me as little as possible (I planned on mounting the brain behind the cluster).
Old Mar 4, 2005 | 12:45 PM
B18C_EJ8's Avatar
Mount it anywhere that's accessible so you can adjust it when you need to....
Old Mar 4, 2005 | 12:47 PM
I dont care that I have to go out of my way to adjust it. I want it in a location that it will be most effective
Old Mar 4, 2005 | 12:55 PM
B18C_EJ8's Avatar
Default Re: (pdiggitydogg)
What's your manual say on where to mount it or to which surface you should mount it? I know DEI says to wire tie it to a main harness.. Not sure about Compustar...
Old Mar 4, 2005 | 12:58 PM
doesnt say
compustar is seriously into having them professionally installed, rather than owner installed
Old Mar 4, 2005 | 01:01 PM
B18C_EJ8's Avatar
Doesn't really make sense to not put it in the manual... I mean, how do they expect the dealers to know where to mount it for proper operation if they don't put it in the manual...
Anyways... With Viper alarms, they want the shock sensor tightly ziptied to a main wiring harness for best results. But others want it screwed to metal somewhere under the dash.
Does the sensor have mounting flanges on it for screws? If so, screw her down. If not, well, try ziptying it. :shrugs:
Old Mar 4, 2005 | 01:06 PM
well...its got both screws and a tie
I like the idea of the harness, maybe I'll try that first and if I dont like it, I'll put it somewhere else later
Old Mar 4, 2005 | 01:58 PM
DC2 to AP2's Avatar
this is where i mounted my compustar shock sensor in my 98 integra.
Old Mar 4, 2005 | 03:11 PM
hmm....looks good to me.
Did you ever figure out how to wire yours up imola? I saw your post asking about wiring help.
Old Mar 4, 2005 | 03:48 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
for DEI alarms such as cliffords and vipers... they want you to zip tie the shock sensor to a harness that will jiggle when the car gets hit
Old Mar 4, 2005 | 04:01 PM
DC2 to AP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">hmm....looks good to me.
Did you ever figure out how to wire yours up imola? I saw your post asking about wiring help.</TD></TR></TABLE>
yep sure did! its pretty much all wired now.
chrisw
Aug 10, 2010 10:22 AM
BrothaSit
Dec 14, 2008 07:13 PM
D50boy
Audio / Security / Video
Feb 22, 2008 12:46 PM
stackz
Nov 15, 2006 01:04 PM
jinu
Sep 14, 2004 12:42 PM
